Brake pads?
Old Jan 13, 2018 | 07:14 PM
LIL-JOE's Avatar
LIL-JOE
Brake pads?
Hello i am new to the forum. I am looking for advice on front brake pads i have a 1994.5 F350 crew cab 4wd
Dually 7.3 powerstroke. I drive it daily and tow 5000+ at least once a week. The problem is truck does not stop well
empty or loaded. Partial due to the rear drum brakes.. I have narrowed it down to 2 pad sets. Wagner extreme sx450 or motorcraft brsf450 super duty pads. any advice would be appreciated. Thanks in advance joe
Old Jan 13, 2018 | 07:27 PM
z31freakify's Avatar
z31freakify
You sure your braking system is good, i have never had a problem stopping my truck pulling my 5er or my old TT loaded both hit 9k+lbs, also you might consider installing elctric brakes to your trailer.
Old Jan 13, 2018 | 07:44 PM
madpogue's Avatar
madpogue
The truck DOES or DOESN'T stop well?
Are you interested in PADS (front) or SHOES (rear)?
Old Jan 13, 2018 | 08:18 PM
LIL-JOE's Avatar
LIL-JOE
It doesn't stop well. Looking for better front pads . I have trailer brakes. On my daily drive to work with no trailer and no load it should stop on a dime like my 2002 excursion does . I have replaced ever part in the system. short of converting it to hydro boost , i would like to try a more aggressive pad . Just looking for advice thank you joe
Old Jan 13, 2018 | 08:20 PM
DDPJ's Avatar
DDPJ
If it's never been done or been awhile, you might want to have the brake system drained and new fluid put in. You could have some air in the lines.
Old Jan 13, 2018 | 08:25 PM
Red97350's Avatar
Red97350
Make sure that your rear drums are adjusted well and x2 on flushing your brake fluid.
Red
Old Jan 13, 2018 | 08:38 PM
LIL-JOE's Avatar
LIL-JOE
I have a snap on vacuum bleeder i have put at least 2 quarts of fluid through it thank you
Old Jan 13, 2018 | 08:44 PM
DDPJ's Avatar
DDPJ
Your vacuum pump could be failing. Mine went out on me pulling a 16k load. Fortunately I was going slow and had room in front of me. Thought I was going to push the brake peddle through the floor before she finally stopped. What a helpless feeling.
Old Jan 13, 2018 | 08:47 PM
97-psd's Avatar
97-psd
The truck should stop better than that. Especially with that many new parts. Does the pedal feel hard or just soft?
Old Jan 13, 2018 | 08:50 PM
LIL-JOE's Avatar
LIL-JOE
Funny you say that mine locked up last week . Had to clean melted rubber off of everything
Old Jan 13, 2018 | 08:55 PM
LIL-JOE's Avatar
LIL-JOE
It stops just not as good as i think it should. just want to upgrade pads. Any suggestions?
Old Jan 14, 2018 | 07:27 AM
Red97350's Avatar
Red97350
I've heard pretty good things about Hawk pads.
Red
Old Jan 14, 2018 | 02:10 PM
Hit Man X's Avatar
Hit Man X
I have Porterfield pads and shoes on the dually. No noise snd low dusting. R4S is the pad material. Maybe 1000 miles so I doubt the rears have even broken in yet. But past experience with them on vintage BMWs was positive.
If you have not pulled the drums, do it. Do not be surprised if there is a mess in there. I had two primary shoes on one side and two secondary on another. Both auto adjusters tossed in there hooked to nothing. One drum was also gouged to **** so I had to replace both to start fully fresh.
New fluid is a given. I try for every few years.
If you can find SS flex lines, let me know. I heard Crown has them for a dually. Until I track that down, I just went with new rubber flex lines.
Good luck and I would love to see a picture of the 4x4 dually!!
Henry16414
Apr 1, 2019 08:06 PM
timo944
Mar 3, 2013 01:43 PM
Smoke2008
6.7L Power Stroke Diesel
Feb 11, 2012 12:30 PM
sprintnut
Jan 29, 2009 06:41 AM
Big Red 00 F350
Jul 29, 2005 09:00 PM
