Braking improvements needed
Old Jul 27, 2005 | 11:58 AM
Big Red 00 F350's Avatar
Big Red 00 F350
Got new brake pads on mine all around and rotors in good shape but doesn't seem to brake as well as I think it should. I pull a 36 ft 5th wheel often and could use more braking capability that is available.
1)Any suggestions on how to check the braking capability? distance to stop test, etc.?
2)Can anyone suggest what to check that might need to be repaired, pm'd to make improvement?
3)Also, what suggestions for mods to improve braking performance.
Thanks
Old Jul 27, 2005 | 02:44 PM
randle_ford's Avatar
randle_ford
I would check the braking system on the trailer. I am assuming that if it is a 36' 5th wheel you have electric brakes on the trailer. If you don't have brakes on the trailer than without a doubt you are stressing the brakes on your truck, not to mention it is very dangerous.
Assuming you have brakes on the trailer,
1. check the brake receptacle/connector and ensure all the pins are making good connections
2. ensure your brake unit is properly synchronized with the truck brakes
3. check the braking system (pads, shoes) on the trailer
Old Jul 27, 2005 | 02:49 PM
Big Red 00 F350
thanks randle_ford for the info. I did not post info originally about the trailer brakes but I have done all that and they are at their peak.
My point is the truck does not seem to have great braking response unloaded with no trailer in tow. I am wondering if it is braking to spec or not as it is...
Old Jul 27, 2005 | 03:04 PM
Kwikkordead's Avatar
Kwikkordead
The best way to break in new brakes is to drive along with a very light pressure on the brake pedal for a few miles. That will mate the pads to the rotors and produce what is called friction coal dust between the pads and the rotors. Also OE pads work the best, I don't know what brand you put in but some aftermarket pads just dont work right.
Old Jul 27, 2005 | 09:42 PM
Big Red 00 F350
Kwikk,
Thanks for the info. I did know about the burn-in technique.. good idea.
I did use Ford OEM pads when they were changed!!!...
Old Jul 27, 2005 | 11:09 PM
Kwikkordead
Originally Posted by Big Red 00 F350
Kwikk,
Yeah go break them in and you should have great brakes. Whenever I do a brake job I go out and do that. After about 200-300 yards the brakes feel twice as "sticky" as when I pulled away from the shop.
Old Jul 28, 2005 | 12:29 AM
MentalState's Avatar
MentalState
I JUST HAD ALL NEW ROTORS PADS AND CALIPERS PUT ON MY O1 F350 WITH ONLY 32000 MILES..Anyway dealer covered it..But I was talking with mech and he said that they have floating pads..And my old calipers had froze up..so they werent floating...
Once they changed everything out she stopped alot better..What I am trien to say is you might need new calipers....
Old Jul 28, 2005 | 07:55 AM
Mike Allen's Avatar
Mike Allen
I went with Applied Rotor Technology rotors for the front of my truck. I have been very pleased with the results so far and agree with Kwik that bedding in the brakes is critical to good performance and longevity. I caution you though the ART rotors are expensive due to the cryogenic process used to treat the rotors.
I have had the rotors on for over a year and have towed everything from car haulers up to a 30' travel trailer and have had no issues.
Old Jul 28, 2005 | 08:38 AM
roaky81's Avatar
roaky81
One thing to do is to bleed the brake lines to remove any possible air bubbles. I'm wondering about the post for the floating calipers, all that means is the caliper can slide left or right to apply even pressure with both pads. If they didn't float, I would think a cleaning of the pin / caliper hole would fix it. The other thing to check is to make sure the pads don't bind up in the caliper. Cryogenic processing on rotors? Next thing to find now is a flux capacitor!
Old Jul 28, 2005 | 09:22 AM
Big Red 00 F350
Kwikk,
I meant to say I did not know about the pad burn-in.
Thanks
thanks to the other guys for the ideas. I actually had the Ford Diesel guy do the brakes when I first bought the truck since I was in a hurry to go haul something heavy...
I need to take the time to open it up and look at calipers and brake linings and bleeding of lines, etc. I guess.
Old Jul 28, 2005 | 09:24 AM
Big Red 00 F350
Does anyone know the spec stopping distance for a 2000 f350 dually?? Can I test that and see what I get and if it is close to the spec???...
Old Jul 28, 2005 | 09:33 AM
Kwikkordead
That I don't know. I would go out and try a panic stop somewhere on a clean dry patch of pavement where you have some room and see if the ABS comes on or not. If it does, I would say you're good to go.
Old Jul 28, 2005 | 09:41 AM
Big Red 00 F350
thanks kwikk. I just need to know right now if it is doing 60% of spec or 90% or what. If it is really low, then I need to do checking sooner.
I haul a very heavy load 16K lbs. 5th wheel which is over what is recommended for the F350 and at least I need to be sure all is running as good as it can with what I have both on the trk and trailer......
Old Jul 29, 2005 | 09:29 AM
Mike Allen's Avatar
Mike Allen
Yep....cryogenic treating of metals has been a recognized method of strengthening metals for some time. I believe most professional race teams regularly treat certain components for longevity purposes. Do a Google search on the topic it is quite fascinating...well at lest for us engineers.
Old Jul 29, 2005 | 09:00 PM
johnny8's Avatar
johnny8
count yourself lucky... my boss has two F350's for work trucks... one with 34k miles and one with 23k... both trucks have gone in for noises in the front end.. BOTH trucks needed pads AND rotors all the way around...! none of it was covered by warranty...! my boss is STILL PISSED...! i doubt he will buy a ford the next time he needs a work truck... part of the problem is the stealership.. i think they are yanking his chain and selling him parts he doesn't need, i doubt he will be taking those trucks back their EVER again... bad way to do buisness.. but they are the only ford dealer in a small town so i don't think they care... still... i was considering buying my wife's next vehicle from them... not anymore...!
