Driveshaft Compatibility
What driveshafts are the same, at least for the front half, as the driveshaft on a 92 F-250? I broke the center u joint yolk trying to pound out a broken u joint.
Details on the truck is ZF 5 speed, extended cab, 8' bed, 2wd. I measured the front half of the drive shaft at 58" from the center of the front u joint to the center of the middle u joint.
There is a local pick a part that has a few f-series trucks but most are automatic so I don't know if they would fit.
damesta
02-05-2018 01:45 PM
JayP63
10-26-2017 06:35 PM
longview1
06-03-2004 01:05 AM
