1989 F150 4.9 intermittently dies - Ford Truck Enthusiasts Forums
Old 01-12-2018, 10:22 AM
tnab1970 tnab1970 is offline
tnab1970 is starting off with a positive reputation.
OK, guys need some input. 1989 F150 4.9L , 5 speed. New long block, ALL new ignition, not distributor but new PIP sensor. Fuel pumps putting correct pressure at idle. New filters, new in-tank pumps, we have replaced ALOT of parts.Runs great, most all the time. Intermittently when you push in the clutch to come to a intersection, it idles down so low it dies. Always starts right back up. Does not do it every time. Could this be the Throttle Position Sensor? or Idle Air Control ? ( one of the few things we did not replace )
thanks in advance.
Old 01-12-2018, 10:53 PM
ROMAD0508's Avatar
ROMAD0508 ROMAD0508 is offline
ROMAD0508 is starting off with a positive reputation.
I was having an issue with a high idle while in park then when in drive the truck would almost die before I gave it gas to get rolling. Ended up being the TPS. That is what I would try.
Old 01-13-2018, 03:46 PM
It does have very high idle when cold. 1200-1400RPM. Ill check TPS
Thanks
1989 f150 4.9 R&R injectors = high idle tnab1970 1987 - 1996 F150 & Larger F-Series Trucks 2 09-29-2017 09:18 PM
1989 f150 4.9 fuel delivery issue again tnab1970 1987 - 1996 F150 & Larger F-Series Trucks 26 09-06-2017 10:41 AM
4.9L in a 1989 E150 - Dies while driving Zia-Lycan Ford Inline Six, 200, 250, 4.9L / 300 5 03-31-2017 11:25 PM
Dying at idle cougfan87 Ford Inline Six, 200, 250, 4.9L / 300 6 05-14-2016 03:32 PM
MAP sensor? vintagequest 1987 - 1996 F150 & Larger F-Series Trucks 5 01-20-2016 06:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
