Truck died won't start
Old 01-11-2018, 11:42 AM
johnboggs21's Avatar
johnboggs21
johnboggs21 is offline
I've got a 97 f350 all stock, died this morning on the way to work just like someone shut the key off. Wait to start light and tach seems to have quit working. Check engine light came on when she died but is out now. Tried swapping in a new cam sensor with no luck. Thoughts?
Old 01-11-2018, 11:49 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Old 01-11-2018, 01:33 PM
farmert's Avatar
farmert
farmert is offline
If you have no wait to start light when the key is first turned to the run position, check fuse #22 in the under hood fuse panel. If it is blown, unhook the fuel bowl heater and replace the fuse, as it powers both the fuel heater and the PCM power relay.
Old 01-12-2018, 11:02 AM
johnboggs21
Unplugged the fuel heater and changed fuse 22 which was blown, no wait to start still. Trying to find the red power wire for the computer
Old 01-12-2018, 12:35 PM
madpogue's Avatar
madpogue
madpogue is offline
Is the fuse blown again?
Also check fuse #9 underhood.
Old 01-12-2018, 01:14 PM
johnboggs21
Fuse 22 isn't blowing again, and fuse 9 is good
Old 01-12-2018, 01:26 PM
madpogue's Avatar
madpogue
madpogue is offline
Check the PCM power relay. I **THINK** relay assignments are in the Fuses section of the owner's manual.
Old 01-12-2018, 01:35 PM
Hussler's Avatar
Hussler
Hussler is offline
Sure you unplugged the fuel heater wire? Second down from top on drivers side. Spade type of connector, real hard to unplug. Sometimes you can't see fuse 22 blown, need to verify with an ohm meter.
Old 01-20-2018, 02:20 PM
johnboggs21
Does anybody have a picture of which wire in the plug is the one that Powers up the pcm? My fuel heater is unhooked, and I confirmed the fuse good. I tried swapping in a known good pcm from another truck with no change. I also tried hooking up a snap on scan tool but it says it's unable to communicate with either pcm. I think my issue is still power not getting to the pcm, but I'm not sure exactly which wire should have power and I haven't been able to find pinout of the plug
Old 01-20-2018, 02:26 PM
johnboggs21
Also does anyone know where to get another diode? I figured just replace it for stupidity sake
Old 01-20-2018, 02:49 PM
fordpride's Avatar
fordpride
fordpride is offline
Old 01-20-2018, 02:59 PM
madpogue's Avatar
madpogue
madpogue is offline
Check for power at the red/green wire, small terminal, on the GP relay. That's the same circuit.
Boneyard, maybe, for the PCM diode.
FUJINAMI1293
07-07-2012 09:11 AM
bigfordandjeep
15
04-06-2009 09:18 PM
clajoie
17
04-26-2008 11:51 AM
vancouverpower
01-18-2005 02:29 PM
JAX
01-23-2003 08:53 AM
Quick Reply: Truck died won't start
