EBPV outlet freeze plugs - give away - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Reload this Page >
Old 01-18-2018, 09:42 AM
kameronth's Avatar
kameronth
kameronth is offline
kameronth is gaining momentum as a positive member of FTE.
Since I have my turbo off I am also in the process of deleting my EBPV among other things. I already ordered and received the deleted pedestal and I removed the butterfly and plugged the hole in the housing with a 3/4 freeze plug. I ordered what I thought was two Melling 3/4 brass freeze plugs from autoplicity for 70 cents each plus shipping. Turns out, it was two 10 packs for 70 cents each. So now I have 19 freeze plugs...
I'm not sure if USPS will accept them in a letter size envelope but if anyone wants to give it a shot, send me a SASE and I will send you one free of charge(US only). Send me a message for my info.
I also sprayed the turbo housing with some VHT "Old Ford Blue".
Old 01-18-2018, 03:59 PM
B-Rad88's Avatar
B-Rad88
B-Rad88 is offline
B-Rad88 is starting off with a positive reputation.
I'm literally about to go to o rillies to get some VHT to paint the turbo and was thinking of this same exact color. I had the 1.0 housing and bypassed exhaust fitting ceramic coated black.
Old 01-18-2018, 04:15 PM
mcali2's Avatar
mcali2
mcali2 is offline
mcali2 is gaining momentum as a positive member of FTE.mcali2 is gaining momentum as a positive member of FTE.
Nice!. I welded that hole up.
Old 01-18-2018, 08:00 PM
kameronth's Avatar
kameronth
Did you pre-heat the cast iron? I have a welder but my skills are low. I know many people that just use a freeze plug but Id rather weld it up too.
At least the outlet can be removed fairly easy without removing the whole turbo if I needed to weld it later on.
Old 01-18-2018, 08:06 PM
kameronth's Avatar
kameronth
I like the color. Its actually left over paint I had from when I rebuilt my 4R100 on my previous F250 4 years ago. This thread has pictures and the build of the painted transmission.
https://www.ford-trucks.com/forums/1...-my-4r100.html
Old 01-19-2018, 05:40 AM
BuddyBarnes
BuddyBarnes is offline
BuddyBarnes is starting off with a positive reputation.
I welded mine without preheat.
Old 01-19-2018, 07:59 AM
mcali2's Avatar
mcali2
mcali2 is offline
I just welded it without preheat. I have welded cast many times and never had an issue.
Old 01-21-2018, 07:25 AM
Shawn MacAnanny
Shawn MacAnanny is offline
Shawn MacAnanny is starting off with a positive reputation.
I took a bolt, ground the edges down so it was slightly round, dropped it in and welded it. No preheating or cooling, was on there 10k with no issues until i replaced with a new turbo and blank one.
Boostingaz
12-27-2017 06:03 PM
gypsytpr
23
09-20-2017 09:26 AM
mattmattn
09-18-2017 08:21 AM
BdgrDuckHntr
23
07-03-2017 08:48 AM
jayro88
21
05-11-2017 08:53 AM
Quick Reply: EBPV outlet freeze plugs - give away
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
