Crank No Start
Old Jan 10, 2018 | 01:44 PM
Pappee's Avatar
Pappee
Crank No Start
1974 F-350 with a 360. Truck was running when i put it away. went to start it after a year. It would not start when i took it out. Had issues with fuel cleaned and rebuilt the carb, cleaned and flushed the tank and replaced the fuel pump. After all that was done all my fuel issues seem to be OK. Now i have a spark issue. I have little to no spark out of primary coil. Ohm test results for the coil are 10.6 Kohms at primary, 1.6 K ohms at secondary’s . Replaced points an condenser, plugs,cap an rotor and tested the coil wire.I have spark everywhere but little to no spark out of primary and no spark the plugs. All plug wires tested fine. Tested number 1 distributor position is good and still no run. Totally baffled. Please Help
Pappee
Old Jan 11, 2018 | 08:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
First, WELCOME to FTE!
How's the battery voltage? What voltage is between the (+) side of the coil and ground while cranking?
Old Jan 11, 2018 | 04:24 PM
Filthy Beast's Avatar
Filthy Beast
Coil is pooched.
Primary windings you want to see ~ 1 ohm. Secondaries you want 8 -11 K Ohms.
Might be something behind the failed coil.....something that caused it to fail.
Get back to us after the new coil is in with any problems you might have.....or no problems you have.
Old Jan 11, 2018 | 04:34 PM
krewat's Avatar
krewat
Good catch, FB
Old Jan 11, 2018 | 04:39 PM
Filthy Beast
Originally Posted by Krewat
Good catch, FB
Thanks....
blazer350
29
Jun 18, 2014 04:22 PM
jb50F1
26
Jul 5, 2010 07:37 PM
danbov
Sep 25, 2007 02:15 PM
trick_5_0
Oct 19, 2005 05:19 PM
lostinfordland
Oct 2, 2003 04:53 PM
