Won't start
Old Oct 1, 2003 | 06:43 PM
lostinfordland's Avatar
lostinfordland
Exclamation Won't start
86 Full size Ford Bronco 302 Fuel injected getting no spark out of the coil. Just had the icm tested and passed, will crank over, just not getting any spark
Old Oct 1, 2003 | 07:54 PM
Ratsmoker's Avatar
Ratsmoker
It could be the coil. You can have that tested as well.
Old Oct 1, 2003 | 10:30 PM
circledirt's Avatar
circledirt
Make sure rotor is turning in dist. while cranking. If so, connect jaws of test lite to pos battery terminal. Stick pointed end in neg terminal of coil connector. You can unplug this connector and look down coil connection for pos - neg terminals. Then, while cranking, if test lite flashes and there,s no spark from coil, its the coil. If no flashes and the ign module is good and is has power and ground when its supposed to its probably the pick up coil inside dist.
Old Oct 2, 2003 | 09:29 AM
lostinfordland
Thanks for the info fellas. I will be doing these checks on the coil today. I'll let yall know how it goes.
Old Oct 2, 2003 | 04:53 PM
lostinfordland
Hey guys, you were right. About a month ago I had tried to replace the pick up coil inside but ended up breaking a tooth on the gear so I just went and got another distributor at one of your brand name auto stores. I figured since I just replaced it, it must be good. Well, today I went out and bought and changed the coil and was still not getting any juice through the coil so of to the store I went again. Changed the distributor out again (still under warranty) and presto, Nelly, my Bronco, started right up. I appreciate the input guys and you can rest assured I will seek your advice again soon, she stalls out after running a while, but that is a problem for another day. Once again folks thanks for the help.
