Sponsored by: Auxito
Heater control valve
Old Jan 9, 2018 | 04:48 PM
robenz78's Avatar
robenz78
Hello there! Please help I have a 2000 ford f150 pickup 5.4/4.6 engine..and heater is not working. has a new heater coil and new thermostat. blenddoor seems to be working. heater control valve is missing. I want to know where exactly does it go.. left, or right hose ? Other thing is that I don't see no vacuum line's loose around the engine the one supposed to be attached to the heater control valve. The heater is not working not even the defrost.if anyone can help. Please
Old Jan 9, 2018 | 05:37 PM
steve(ill)'s Avatar
steve(ill)
the "control valve" you are talking about is probably the optional on- off valve located at the end of one heater hose. You don't need that. You can have water flowing thru the heater all the time... you control the TEMP of the air by routing the air THRU the heater core or AROUND the heater core with the blend door.
problems can be the blend door, or no circulation of water. You said you have a new heater core and a new thermostat. I assume the dash gauge says the engine temp is in "mid range" ? .... The blend door is a MAJOR concern. Why do you think it is working ?
Feel the heater hoses into and out of the core. Are they HOT ? If so, the water is circulating . Temp is controlled by the blend door.... you may need to look into that area.
Old Jan 10, 2018 | 09:29 AM
robenz78's Avatar
robenz78
Thanks I'll replace a new actuator to blend door. Too see if that helps. I'll get back to you too as soon I replace the new actuator thumbs up. 👍
Old Jan 10, 2018 | 01:06 PM
steve(ill)'s Avatar
steve(ill)
problem can be the actuator, OR THE DOOR.
Old Jan 11, 2018 | 06:24 AM
projectSHO89's Avatar
projectSHO89
You need to check the heater hoses first. Until you determine which side of the firewall the problem is on, you're just guessing in the dark.
If there is no hot coolant circulating through the core, replacing the actuator or blend door is a waste of time and money.
Old Jan 11, 2018 | 08:25 AM
robenz78's Avatar
robenz78
2000ford f150 heater
Hello my friend well water is running thru .I can feel a little bit of heat on feet at passangerside but not anywhere else. but it's just not throwing heat and fan is blowing all speeds.I ordered the actuator waiting on it. we'll see wut happens.
Old Jan 11, 2018 | 11:08 AM
projectSHO89
That is NOT a definitive test. All it means is SOME liquid is circulating. If does not mean that coolant is circulating properly or is fully up to the temperature needed for adequate heating. [emphasis added...]
Without doing the recommended checks and tests, you're still just guessing (probably wrongly....again).
got2befast
Oct 28, 2010 11:10 PM
orden09
1983 - 2012 Ranger & B-Series
Feb 14, 2010 09:37 PM
Ranger Ron
Oct 7, 2008 02:00 AM
blue ranger
Jan 30, 2005 11:31 PM
cigarxtc
Jan 19, 2005 11:27 AM
