heater control valve
Old Feb 11, 2010 | 09:57 PM
orden09's Avatar
orden09
i was wondering if anyone can help me locate my heater control valve its on a 2003 ranger
Old Feb 12, 2010 | 10:00 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Look under the hood near the a/c accumulator. It will be black plastic with vacuum line attached and two heater hoses connected. The purpose is to shut off the water flow to the heater core when the a/c is turned on.
Old Feb 14, 2010 | 09:37 PM
Spindoctor's Avatar
Spindoctor
If you're having heat issues, check the hoses in and out of the heater core. If they're both hot, your problem is likely the dreaded blend door. There are a number of fixes which range from cutting the heater box to gain access to the door, or removing the dashboard to get to the heater box. Do all your investigative work upfront. Google is a good friend on this issue.
544tess
Nov 24, 2015 10:54 PM
MarauderV8
Dec 17, 2014 01:44 PM
hodges710
Oct 22, 2011 08:52 AM
C-700
Jan 19, 2009 11:17 AM
cbfomoco
Nov 27, 2007 10:56 PM
