problem solved! (fuel filter)
Old Jan 9, 2018 | 11:35 AM
fabchef's Avatar
fabchef
Hi everyone, well as i had posted before, i've been having some odd issues with our 2001 e150 van. I thought it was a tranny thing as when i would floor it, the engine would rev up but go no where. It would often have a hard time starting in the morning, even on slower speeds, it would kinda buck back and forth and when driving on an incline, there was no power.
I thought maybe it was the serpentine belt going bad, changed it, wasn't it. Then i thought.."hmm maybe not enough fuel"? i saw there was a fuel filter on it, and didn't know if it had ever been changed, so i had it changed a few days ago. Today i had a chance to try it out (got lots of snow on the ground and don't wanna kill myself), i floored it and the van came back to life and took off! As well, i noticed no more weird screeching noises coming from engine compartment. When in park or at a stop light its hard to tell if the engine is running! very smooth, unlike before (stumbling).
So if you have some of these issues, maybe have your filter changed?
fab
Old Jan 9, 2018 | 06:13 PM
wiskeyVI's Avatar
wiskeyVI
Thanks for sharing.
Old Jan 9, 2018 | 09:06 PM
vettex2's Avatar
vettex2
Good to know.
Old Feb 21, 2018 | 12:42 PM
Thenne1713's Avatar
Thenne1713
Glad the filter fixed it, but re: screeching, belts/ serpentines can make some weird noises, and new may fix; (but) new may (soon) start making noise also (because) idlers and pulleys will develop surface rust within hours, and being off for days/ weeks can make things worse and noise return. The good news is that the noise will go away in 5-15-minutes.... when it does not, then it is time to check bearings/ belts. :-) Best to you..
Old Feb 27, 2018 | 10:10 PM
fabchef's Avatar
fabchef
Update*** now I got it!
so I thought I had solved the problem by changing the fuel filter (which was still a good thing to do). The van had been sputtering and getting a little worst by the day. TODAY...finally! The "check engine" light started flashing and stayed lit...yay! Took the scanner and showed "misfire on cyl #3". So I got a new plug, when I took out the old one, the rubber end (that goes over plug) had started to split down the middle!! Putting the new one in was a b-+ch! It didn't seem to sink in over the plug, but I tightened it and the van is running like a champ. Btw...whoever designed these curved plugs, should be flogged with a wet noodle! Super poor design and don't sit properly.
Old Feb 27, 2018 | 11:14 PM
kennyfzj80's Avatar
kennyfzj80
Glad you got your issue resolved but please watch the language around here.
Old Mar 12, 2018 | 08:17 PM
fabchef's Avatar
fabchef
oups..sorry.
What i did want to know is....the coil that i put in was not OEM. Is there an easy way to get the coil on? i was pushing down on the coil so hard, and when i let go it would kinda bounce back up, is this normal?
thanks
fab
Old Mar 20, 2018 | 10:48 AM
VansFormer's Avatar
VansFormer
Um what language? wet noodle? flogged? you realize the OP is chef? lol
Old Mar 20, 2018 | 10:52 AM
VansFormer's Avatar
VansFormer
Thanks for posting this I am going through the exact same situation except its cylinder 6 missfiring. I have it in today getting all new plugs and coils. Im not leaving anything to chance like the piece of mind a full tune up with fresh parts. Your post gives me hope that mine will be fine. Im at 110thousand miles so a refresh could not hurt.
Old Mar 20, 2018 | 10:29 PM
HighballHighlife's Avatar
HighballHighlife
Thanks for sharing. Having almost the exact same issues in a 88 E350 7.3L IDI and also thought fuel filter and/or glow plugs. Looks like injector lines are leaking though. Which, for me, is much more disappointing. Kind of explains my MPG though. Not that it was great before I was leaking fuel haha.
Old Mar 21, 2018 | 05:59 AM
Im50fast's Avatar
Im50fast
lol I thought the exact same thing
Old Mar 23, 2018 | 03:56 PM
VansFormer's Avatar
VansFormer
I got my van back. I had all plugs replaced and boots and coils. All codes are clear and sensors are complete now.
The engine noise is back to very smooth sounds now and I lots more power. I'm sure I've been suffering with the cyl 6 coil for quite awhile before it finally cacked. it like driving a completely different vehicle.
jasontaylor
Jan 20, 2010 05:05 PM
matrix660
2004 - 2008 F150
Feb 24, 2009 11:59 AM
GoCamping
Dec 17, 2006 08:51 PM
tommyzax
Jun 17, 2003 01:44 PM
