Stock OBS Alcoa Wheel Specs (width, offset)
Old Jan 8, 2018 | 12:17 PM
240dx's Avatar
240dx
Ive searched but I cannot find consistent answers, just people assuming and guessing. Can anyone please tell me for sure what the width and offset for the 16" OEM F350 OBS Alcoa wheels are? Thanks
Old Jan 9, 2018 | 03:54 AM
bart f-350's Avatar
bart f-350
Are they intended to go under a Ford OBS pick-up?
They are made for a 235/85R16 tire and designed to go under a OBS Ford pick-up.
Goodday
Old Jan 9, 2018 | 08:07 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Goodday
I don’t understand your answer. That has nothing to do with the question.
Old Jan 9, 2018 | 08:13 AM
Bruce W.'s Avatar
Bruce W.
7" width. I don't know the offset.
Old Jan 9, 2018 | 08:21 AM
wharthog's Avatar
wharthog
E-350's have a width that is 1" wider, why I don't know. As for the offset, I don't know what it is But if the answer is not known I will have mine off later today and I can measure it for you.
Old Jan 9, 2018 | 09:45 AM
FordTruckfan89's Avatar
FordTruckfan89
Backspacing is probably 3-3.5, 7" wheel.
Old Jan 9, 2018 | 01:04 PM
wharthog's Avatar
wharthog
Well, pulled my tire and set a cross piece across the tire and measured to the mounting surface. It measured 5.250" then I subtracted the distance from the cross piece to the rim lip, that was 1" so from the mounting surface to the rim lip is 4.250 on my rims. They also have the small recesses for the ford hub cover to mount in. If you want to see the measurement, pm me with your phone number and I can send you a pic. I hope this helps you in your planning.
Old Jan 10, 2018 | 07:33 PM
Diesel_Brad's Avatar
Diesel_Brad
16x7
4.25" back spacing
8 on 6.5 bolt pattern
Old Jan 11, 2018 | 06:53 AM
wharthog's Avatar
wharthog
DB, did you just sum up the info or did you find it somewhere? This post actually had me wondering if the E-series that is an inch wider had the same offset.
Old Jan 11, 2018 | 02:54 PM
Diesel_Brad
I have 3 sets of those wheels in my my parts garage
And NO the e-series wheel is NOT an inch wider I have one set of those in aluminum and 2 in steel
69F350man
Feb 19, 2017 11:54 AM
Brom014
Oct 29, 2012 09:02 AM
4DOORSR
2004 - 2008 F150
Jan 28, 2009 09:58 AM
mattd17
2004 - 2008 F150
Jan 15, 2008 07:27 AM
Knobby4604X4
May 23, 2003 01:37 AM
