1970 f250 break problems
Old Jan 7, 2018 | 10:01 PM
ridonkeris's Avatar
ridonkeris
I have bled the brakes a couple of times it used to be that you would put the truck in neutral and step all the way down the brake and it would stop you eventually now I don't have any brakes until my foot gets to the floor at which point it's immediate full on so every time I step on the brakes it's like I'm stomping on them. It feels like a hundred percent of the breaking power all condensed into the last 10% or 5% of the brake pedal travel. Anyone had this problem or know how it can fix it
Old Jan 8, 2018 | 04:46 AM
GaryKip's Avatar
GaryKip
First off, are these drum breaks all the way around, or disks in the front? Next question, how long since the breaks were adjusted at each wheel hub? Is the vac. booster hooked up and working?
Old Jan 16, 2018 | 06:48 PM
JEFFFAFA's Avatar
JEFFFAFA
Why were you bleeding the brakes in the 1st place. Did you replace the Master Cylinder recently? Or other brake components.
Old Jan 18, 2018 | 11:13 AM
Tedster9's Avatar
Tedster9
Sounds like from information provided master cylinder is failing.
Old Jan 23, 2018 | 04:28 PM
JEFFFAFA's Avatar
JEFFFAFA
That or OP bought one of those booster/M.C. combo units. Which come with a rebuilt (not a good idea) M.C. and a new booster. I'm thinking the booster rod isn't adjusted right.
truckfella
Modular V10 (6.8l)
17
Mar 16, 2020 11:59 AM
troubledford
Oct 18, 2010 07:41 AM
jux
Oct 16, 2005 03:41 AM
shortblock2000
Apr 8, 2005 12:14 PM
frd56f100
Jul 23, 2001 08:44 AM
