6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Diesel 911 HELP
Old Jan 6, 2018 | 11:42 AM
SUPERDUTY_08's Avatar
SUPERDUTY_08
Diesel 911 HELP
Dumb question, but can I add Diesel Kleen 911 directly to fuel tank? I'm a little confused with the directions. I added the white bottle winterizer last weekend, but with the extreme cold we have been getting. My truck still seemed to have gelled up.
Old Jan 6, 2018 | 12:21 PM
Firefighter 1406's Avatar
Firefighter 1406
I have heard people draining and filling the fuel bowl with it. Then dump the rest in the tank. I personally have never used it though.
Old Jan 6, 2018 | 02:35 PM
Mixer man's Avatar
Mixer man
What kind of temps are we talking about? Only sustained temps below freezing will cause the wax in the fuel to begin solidifying.Where are you located? Good idea to update your CP. Most places that are subject to sustained sub freezing temps will have "winter blend diesel" or #1 diesel. #1 diesel has a lower cetane rating due to it's higher refinement and lower wax content. It's similar to kerosene which has virtually no wax, and consequently no lubricating qualities either. People up in the great white North of Alaska not only use block heaters (which seems to take care of engine fuel), but will wrap the fuel lines and tank with freeze tape (this only works for overnight where you can plug in). Another tip from up North is to add one cup of kero to a full tank of fuel (add kero before filling). It's also advised to use a sulfur additive when doing this. Back in the early '70's when I spec'd trucks for Sea Land, they would have engine coolant piping added to the fuel tanks.
Old Jan 6, 2018 | 02:42 PM
SUPERDUTY_08
i am in western Massachusetts. The temps here have been in the teen's, single digits, and up to -15° the last few weeks. It's currently 8° and winds up to 40mph. My truck didn't come with the block heater cord, but I ordered one and will be on tomorrow.
Old Jan 6, 2018 | 03:19 PM
Mixer man's Avatar
Mixer man
Wow. Yeah you peeps are being hit hard by this storm. During the winter of '88-'89 I was in Siberia. Couldn't be worse than that though - in the minus teens for four months at least.
Old Jan 8, 2018 | 12:01 PM
SUPERDUTY_08
good news! it's going to be 30s and 40s this week. Just in time for that block heater cord to get installed. Lol
Old Jan 14, 2018 | 05:49 PM
speakerfritz's Avatar
speakerfritz
diesel does not unwax with better temps....expect to have to chaingd the undercarriage filter a few times....if it were me...I would drain the tank and run the fuel thru some tied off jeans.
must use anti gel during the winter....
Old Jan 14, 2018 | 07:17 PM
73F700's Avatar
73F700
Diesel will unwax or 'remix' but the temperature required is much warmer than the temp that it waxes at.
We had a truck in the shop this year gelled up. We removed the filter and took it apart on the bench. After a week at 50F it still had just as much gel on it. I believe it needs over 60F, sometimes even warmer, depends on the exact mix of diesel. In our experiment with the filter it was in open air and not submerged in diesel which may have had some effect.
Also for the record, 911 will remix the fuel but does not prevent future gelling. If you are in a spot where you need to add 911, then you also need to add the white winterizer fluid as well.
Diesel Newb
Jan 3, 2014 11:04 AM
cford716
6.7L Power Stroke Diesel
Dec 13, 2010 10:12 AM
Texas Outlaw
Jan 14, 2007 04:22 PM
the weez
Sep 22, 2006 03:18 AM
trike1946
Feb 6, 2005 02:26 PM
