Reversing Lamp Circuit Trigger?
Old Jan 5, 2018 | 02:25 PM
JWA's Avatar
JWA
2005 E250, 5.4 gas engine................looking for a signal out of the Transmission Range Selector as it runs to the actual tail light housing to illuminate the reversing lamps. By my reckoning the Ford EVTM (Cell 93-1 & -2) the Black /Pink wire should be a positive VDC when the DTR shows reverse---is that correct?
I've tapped into the wiring harness just aft of the B Pillar but have only continuity to ground engine on, engine off and regardless where the shift lever is positioned (P, R, N, D, 2 & 1.)
I'm sure I'm missing something. I'm hoping to have reverse lamp operation trigger a back up camera. (Ecco Gemineye K7000B, already installed and operational apart from having a trigger circuit wired in.)
Thanks for looking--appreciate any help or direction!
Old Jan 6, 2018 | 07:23 AM
Franklin2's Avatar
Franklin2
You can't trigger the camera directly from the back-up lights in the rear lighting housings?
Old Jan 6, 2018 | 07:37 AM
Franklin2's Avatar
Franklin2
I looked up the diagrams, if you have a torqshift transmission, there is a relay that this circuit goes through located in aux relay box 1. After the relay, it's a conventional black/pink wire going to the lights in the rear.
If you do not have a torqshift trans, the circuit comes directly from the DTR(digital transmission range sensor) and goes to the rear on the black/pink wire.
Old Jan 6, 2018 | 07:55 AM
JWA's Avatar
JWA
Thanks Franklin1---appreciate the reply!
I don't have the TorqueShift trans, have tried tapping into the black/pink wire but in-line, not after the bulb in the tail light housing.
No---which did puzzle me since schematically there should be power anywhere along the circuit wire after the DTR. It finally dawned on me maybe I'll get needed + 12VDC by inserting a tap between the reverse lamp lead that is grounded.
When this van was new to me there was an inside cabin audible back up alarm, wired as described above. The alarm wasn't working so I removed it, taped the wire for insulation.
It also dawned on me I have a constant ground from my splice/tap in the wiring harness pre-lamps because I'm seeing a signal through the reverse lamp bulbs to the ground.
Old Jan 6, 2018 | 08:57 AM
alloro's Avatar
alloro
Yes the BK/PK wire will go to +12vdc when shifting into reverse. Keep in mind it's only hot when the key is on and the shifter is in reverse. If that's not happening it's possible you've tapped into the wrong wire. Also, double check and make sure your reverse lights are coming on. You could've blown the fuse by mistake. You should also check for power at the DTR sensor connector to make sure power is coming out of it.
Old Jan 6, 2018 | 11:48 AM
JWA's Avatar
JWA
What I'm not getting is any voltage at my point of tapping or splicing. The lamps in the tail light housings do come on, go off as I'm shifting in and out of reverse. This is with key on in "run" so all is good there.
Thanks guys for looking in---appreciate the help!
Old Jan 6, 2018 | 12:52 PM
alloro's Avatar
alloro
Then you've tapped into the wrong wire. It might be the right color, but it's still the wrong wire.
Old Jan 6, 2018 | 01:02 PM
alloro's Avatar
alloro
These PDFs show the location and connector face, just so you can verify the correct wire, which is pin 9.
File Type: pdf
File Type: pdf
Old Jan 6, 2018 | 02:10 PM
JWA's Avatar
JWA
Your information agrees with my printed EVTM 100% and thanks for posting those .PDF's here.
I'll split the connector apart and look for voltages relative to the DTR sensor's location.
Thanks!
Old Jan 6, 2018 | 03:04 PM
projectSHO89's Avatar
projectSHO89
A continuity check would show a very low resistance to ground in the unpowered circuit since the DC resistance of the bulb filaments is very low.
Old Jan 6, 2018 | 03:26 PM
JWA's Avatar
JWA
Actually I was using my DMM's continuity tone function, testing to see if circuit #140 was ground only. The threshold for a tone is 200 ohms or less so that explains why I was showing continuity to ground.
I'll dig into the connector perhaps tomorrow after a bit of work early morning. It'll be interesting seeing which wire color actually comes from C3136. Removing the tail light housing will help too, checking the wire color to the reverse lamp socket(s).
Old Feb 18, 2018 | 12:20 PM
JWA's Avatar
JWA
Just a quick update----its taken me since Jan 6th to start running this problem down once again.
As it turns out the wire in C3136 Pin 9 is black with a red tracer---when calling for reverse I do have power that's on and off according to the DTR position. Goes to show the EVTM's don't always agree with the actual vehicle.
I did learn to follow the connector pin locations when tracing a wiring issue--color alone might not be 100% accurate.
Thanks to you all for the help, for pointing out what else to check!
Old Feb 18, 2018 | 03:07 PM
Franklin2's Avatar
Franklin2
So the only discrepancy was the schematic called for a black/pink and you found it was a black/red wire? I can tell you from experience, these wires fade and change colors as they age. It can be very frustrating when troubleshooting. I do not think I have ever found a true white wire in the harness, they always fade to a shade of yellow, especially if it's a white stripe on a darker wire.
Old Feb 19, 2018 | 05:02 AM
JWA's Avatar
JWA
Definitely a wire color and tracer issue, age itself being the bigger factor rather than exposure to sunlight or other elements. These wires are pretty much totally covered buried behind trim panels etc. Later I'll try viewing these same wires under better light but still knowing some sort of color shift has taken place.
Sadly I assumed a black/pink wire wouldn't be in the same bundle as a black/red wire so that's on me.
So the lessons learned were: 1) Trace wire colors under good lighting & 2) Check connector locations first.
Thanks again Franklin2 and everyone else for their help here!
DonsFx4
2004 - 2008 F150
Jul 16, 2019 11:55 PM
Steven Gatley Sr
Electrical Systems/Wiring
Nov 7, 2014 08:10 PM
gene daniels
Apr 2, 2013 11:10 AM
vmark
May 3, 2009 01:26 AM
LCAM-01XA
Dec 15, 2008 08:47 PM
