MLPS wiring - backup lights?
Old Dec 13, 2008 | 01:11 AM
LCAM-01XA's Avatar
LCAM-01XA
Which is the wire on the MLPS that engages the backup lights? I got a pair of 3x5" floods up above the bed (right behind the cargo light actually) that I have on a manual switch, but I'd like to have them come on automatically when I put the trans in reverse, so I need to tap into the wire from the trans and use the voltage to trigger the relay for the floods. So yah, which wire I on the MLPS harness I need for that?
Old Dec 13, 2008 | 06:51 AM
PLC7.3's Avatar
PLC7.3
Try the P/O (pink/orange) and B/PK (black/pink)
Old Dec 13, 2008 | 08:10 AM
LCAM-01XA's Avatar
LCAM-01XA
Wait, which one of the two? Or do they both carry current tp the backup lights?
Old Dec 13, 2008 | 10:37 AM
mustangman02232's Avatar
mustangman02232
i wanted to say i tapped a green wire on mine with a strip but im not 100% sure
Old Dec 13, 2008 | 03:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Black/pink from the tranny back.
Old Dec 13, 2008 | 03:31 PM
LCAM-01XA's Avatar
LCAM-01XA
cool, will mess with it tomorrow. thanks!
Old Dec 15, 2008 | 01:03 AM
LCAM-01XA's Avatar
LCAM-01XA
Done! It's like 45 here now, kinda rainy but not really, perfect weather for work under the truck - the wire I needed turned out to be a black one with a purple-ish tracer, not so much pink, but yah, y'all were correct. Now when I put the trans in reverse my flood lights come on, and when I turn the floods on my backup lights come on, I'm happy with the result. Connection at the splice is insulated with heat-shrink of course, just like all my other chassis wiring mods, so it should be good against snow and salt and stuff.
Old Dec 15, 2008 | 04:34 PM
Dave Sponaugle
Is that legal there?
We can have work lights, but no more than two lights can come on when you shift into reverse.
Old Dec 15, 2008 | 08:47 PM
LCAM-01XA's Avatar
LCAM-01XA
Well, that's easily fixed, I can always pull the bulbs off the backup lights then, they're about worthless anyways. That, and cops here usually let you slide with stuff if you can persuade then you're doing it for safety reasons, I've been pulled over many times for my quad-low headlights in my Lincoln and never got a ticked just for that reason.
