I purchased a 2002 F350 SRW 7.3L and its never had a trailer brake controller installed. I absolutely hate the way all the after market ones install. Can you use a Ford OEM TPC on Ford trucks that weren't originally equipped with them? and if not, do that make one that will install in the dash and not on a bracket?
I've seen them mounted in the dash pocket, whatever you want to call it. Keeps it out of the way. Some double sided table/velcro will hold it secure enough and a simple hole in the back of the pocket to allow the wires through.
I used to hang mine under the dash and it was definitely a calf knocker.
That is where I installed the P2. Fits nice and snug. And is completely out of the way while easily reachable when I need to yank on the brakes manually. Seems that it was also Ford's intention as the harness is just behind that pocket too.
