1. Remove the RH headlamp assembly.
2. Position aside the shield as necessary to gain access to the washer pump.
3. Disconnect the windshield washer reservoir hoses.
4. Disconnect the windshield washer pump electrical connector.
5. Remove the windshield washer pump.
6. To install, reverse the removal procedure.
