Help! Performing a vacuum test
This is my first post on the forum, and I have a newb question for the mechanics out there:
I want to perform a vacuum test on my 2003 5.4L v8 e250. It has 170,xxx miles on it. I have looked up the test and know how to read the gauge, but I don't know where to attach it. As I am not a mechanic, please be as simplistic, and thorough in your description as possible. Simply saying "intake manifold" will not suffice, since I don't know what that looks like. If you can attach photos, or link a video, it would be most appreciated, but at this stage, any help at all would be fantastic.
The reason for the test is that the van has a severe lack of power under load. On hills I struggle to reach 30mph, and on the flat, I can only reach about 55mph. In town, on flat ground, the difference is not very noticeable, so long as I don't try to "gun it." The transmission shifts OK, and the engine revs, but the power just isn't there. In fact, when I put the pedal to the floorboard, I generally decelerate. All of these symptoms came about fairly suddenly. I am not getting a check engine light. I have changed the fuel and air filters, and put in a bottle of injector cleaner, but have seen no improvement. (I wasn't really expecting those to be the problem, but I wanted to try the cheap, easy options first)
I now suspect the catalytic converter(s) is clogged or broken. That, or there could be a vacuum leak, or a problem with timing. Perhaps the spark plugs? In any case, a vacuum test should* point me in the right direction.
Can anyone help?
You need to get the engine codes.
Mine ran terribly for a hundred miles before turning on the CEL.
Stop in at a Advance/AutoZone and have them pull the codes. If no codes, keep driving; it’ll come on.
The only thing that could make your van run that bad (without a CEL) would be the catalytic converters or bad fuel.
When I cut my brake booster vacuum line I used a metal tee and put a rubber cap over the unused end. Now I always have easy access to connect my vacuum gauge.
