how to check vacuum?
Old Feb 17, 2005 | 12:19 PM
wresleu's Avatar
wresleu
I can't find anything on here or in my Chilton's about doing a vacuum check. What is the procedure in doing this? Which lines to tap into...what should it read..etc. Anyone who has done this please advise. Thanks
Old Feb 17, 2005 | 12:57 PM
87 XLT's Avatar
87 XLT
A very handy place for hooking up my vacuum gauge on my 2.9 is at the rear/top of the engine where the vacuum hose from the trans modulatorwould go if it had an automatic.
Or you can connect to the PCV.
Once it's hooked up just follow the directions that come with the gauge for the different tests.
A Haynes manual does have info on this, i'm surprised your Chiltons doesnt.
If your engines in good shape you should have a steady reading of around 18 inches or better
Old Feb 17, 2005 | 05:19 PM
el conquistador's Avatar
el conquistador
the best place is at the vacuum tree where all the lines go to the intake manifold. usually there is an extra port that is capped off.
Old Feb 17, 2005 | 07:12 PM
wresleu's Avatar
wresleu
ok, well next question....my truck has those hard plastic green and red vacuum lines. they are very small in diameter and I see no "tree" near the intake....would it be under the intake?
Old Feb 17, 2005 | 08:30 PM
wresleu's Avatar
wresleu
Ran the test. Consistant 18 inches/hg when at idle. No noticeable needle fluctuations. It jumps down to 0 and up to 27 or so when you get on the throttle and goes right back to 18. I'm assuming this is good ??? Should mean my valves/rings are fine right?
Old Feb 17, 2005 | 09:05 PM
Ken00's Avatar
Ken00
Sounds good to me.
reamer
Mar 19, 2014 07:50 AM
Justin's Green Truck
1997 - 2003 F150
Jan 23, 2011 08:20 AM
64F-100
Oct 12, 2010 12:31 PM
hotrod351
Oct 9, 2009 01:37 PM
