6.2L V8 Discuss the 6.2L V8
6.2 marine engine
Old Jan 4, 2018 | 08:36 PM
trinidadboatworks's Avatar
trinidadboatworks
6.2 marine engine
I'm currently planning a 6.2 marine engine build and i was told the 2017 raptor 6.2 engine would be a great place to start, i will be supercharging it, I would like to see about 650 hp any thought about where to start? it will be going in a 27 cat that I'm building
Old Jan 5, 2018 | 07:18 AM
Ron94150's Avatar
Ron94150
The 17 raptor is a 3.5 eco boost.
We have a lot of boat manufactures in my area, I use to install GM Indmar motors at Mastercraft. I've heard a lot of good with the 6.2 marine motors. Seems like they would be a great candidate because of the high revving nature.
If your going to be adding boost and pushing it that far, I would check into the bottom end. I don't know what the marine engines have, but if it is cast, I would call livernois motorsports, and look into a forged bottom end.
Old Jan 5, 2018 | 07:24 AM
Ron94150's Avatar
Ron94150
Not quite the HP number your looking for, but I'm sure it's a pulley swap and tune away. Could you live with 510HP and 580TQ until the warranty ran out? I'm sure that is a very conservative tune since they are warranting it.
https://www.indmar.com/engines/raptor-575/
Old Jan 5, 2018 | 01:57 PM
trinidadboatworks
thank you
Ron
thank you, the 6.2 has a cast iron block i could be wrong on the year but i thought it was 2017 i bought a set of cam for the 2017 6.2 from ford. those cams are on there way to California to a company that is going to make a set that will be a little bit better for a boat engine. i was wrong about the engine it was a super duty 6.2 not a raptor engine, which has 430 lb-ft. @3,800.
Old Jan 5, 2018 | 02:51 PM
Ron94150's Avatar
Ron94150
I was referring to forged crank, rods and pistons.
Old Jan 6, 2018 | 12:29 PM
82_F100_300Six's Avatar
82_F100_300Six
On a boat is the propeller one to one drive straight off the crankshaft? Is this going to be inboard or inboard/outboard?
maxtor
Feb 8, 2017 09:24 PM
cdmm151
2015 - 2020 F150
Oct 23, 2016 03:35 AM
77_f250_custom
16
Mar 2, 2015 01:58 PM
parkland
Aug 9, 2012 09:12 PM
WDK2
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Nov 2, 2005 07:45 AM
