Trans temp question
Old Jan 3, 2018 | 08:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by tfunk88
I agree, but hat seems odd to me is the trans is reaching a higher operating temp when it is super cold out, and when the temp outside is just cold it runs at a lower operating temp. -2 our this morning, trans goes up to 168 then drops to 162. 30 degrees outside on way home and trans doesn’t go over 158.
I never noticed that, but that doesn't mean it isn't happening. I don't have an explanation as to why that would happen.
Old Jan 3, 2018 | 10:26 PM
wedge542's Avatar
wedge542
Snows after you mark,better bundle up, none in 28 yrs till now little northwest of you. Orange juice going up already.
Old Jan 4, 2018 | 05:32 AM
tfunk88's Avatar
tfunk88
Thanks for your help, and to all for their replies! I guess as long as temps don’t get TOO high I’ll just let it ride...and see if I can come up with some kind of wacky explanation for the cold/warm temps enigma.
Old Jan 4, 2018 | 06:28 AM
Mark Kovalsky
It's 34°F here this morning. It's completely clear, so no snow.
Old Jan 4, 2018 | 03:39 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
A thermostat opening is exactly what happened.
There is a thermostat in the transmission. It has a nominal temperature of 165°F to open. Nominal means it's an approximate temperature. Anywhere from about 155-175°F is acceptable.
When the thermostat is closed only a trickle of fluid is sent to the coolers. Almost all of the fluid just recirculates inside the transmission with no cooling. So that trans will warm to normal temps (and 168°F is perfect) in almost any temperature. That's how we designed it.
Why? Because the thermostat is not a digital device. It may open at 162°F one time and 168°F another time. Absolute precision on the opening temperature was not at all important, so no effort was made to make a thermostat that is 100% repeatable.
The thermostat in the 5R110W is a wax pellet, not a metallic. It's the same principle as an engine coolant thermostat.
The stock filter does not work like that. It does not have a thermostat in it. It receives 10% of the cooler line flow at any temperature that there is flow. 90% bypasses the filter. The filtered and non filter fluids are mixed back together and go through the cooler. There is no path for the filter to bypass the coolers.
Interesting it was talked about on another forum as functioning that way. Unless of course I didn't pickup on what they said exactly. May have been thermostat in the transmission decides whats sent off towards the cooler and filter setup?
What I do know about the transmissions is there are expensive to replace and why I have had both of my 2006 flushed at Ford every 30K instead of drain and fill. Along with the 2008 pan and filter installed. Paranoid... yea maybe a bit.
I know that you were heavily involved with its design so that's that. Thanks..
Old Jan 4, 2018 | 04:42 PM
Mark Kovalsky
There are two positions. When closed 10% of the normal flow goes to the coolers. When open 100% goes to the coolers.
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
Wingit929
All Things Towing
16
May 11, 2016 09:11 PM
timsexcursion
2009 - 2014 F150
Aug 16, 2013 08:59 PM
rmblaster
2009 - 2014 F150
Oct 23, 2011 06:16 AM
matttaubert
Dec 24, 2008 10:53 PM
