Torque App/Trans Temp/PID Question
Old Mar 30, 2013 | 06:06 PM
timsexcursion's Avatar
timsexcursion
Anyone here using the torque app?
I recently installed it and the main thing I was interested in was the transmission temperature. My trans temp exactly matches my coolant temp so I'm thinking it's not correct. I'm wondering if anyone here has a fix for this or the correct PID equation...
Thanks!
Old Mar 31, 2013 | 03:23 PM
Eco12's Avatar
Eco12
Couple questions first: what is your temp reading, and if I am not mistaken your have the 6r80 like my '12? I am using the dashboss setup and get around 194-200 operating ect and 190-192 trans. Hope this helps.
Old Mar 31, 2013 | 05:41 PM
timsexcursion
Yes...6R80
I haven't used the app much, but when I start the truck, I can watch both gages (coolant and trans temp). The temperature on both is identical and updates simultaneously. If the temp goes up 1.3 degrees for example, it goes up that much on the other. They both are always the same even after total warm up.
Old Mar 31, 2013 | 07:11 PM
Eco12's Avatar
Eco12
Definitely sounds like something is amiss. My ect always warms up faster than the trans. Not sure how there customer support is, but I would contact them and explain what is happening. The manufacture might even have a forum you could interact with to get more info. I know you have committed to your product, but just as an example the staff at dashboss is very interactive with the consumer to either explain or correct issues. That might be a good place to start. Hope it helps and you get everything figured out.
Old Mar 31, 2013 | 07:56 PM
timsexcursion
I did post on the Torque forum...no responses yet. Hopefully someone will come up with a way to read it correctly eventually
Old Apr 2, 2013 | 12:43 AM
timsexcursion
This problem has been fixed!Over on the Torque forum, someone posted about this and the fix is to go into the 'Manage Exta PIDS' section and edit the 'Transmission Fluid Temp' PID. Scroll to the bottom where it asks for 'OBD Header'. Erase 'Auto' and type in 'TCM' without the quotes. Save and exit. This function now works perfect for me and I hope it helps others having the same problem!
Old May 5, 2013 | 01:35 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Could you post the formula for me? Thanks Curt
Old Aug 16, 2013 | 05:42 AM
Quickfords's Avatar
Quickfords
Trailering
Was this problem ever solved??
How about Engine Oil Temp??
(I have 2000 Excursion V10)
Old Aug 16, 2013 | 06:52 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Yes, but I don't think you have oil temp because your a gasser!
PID:221674 UnitF Max/
Min 100.0/0.0
Equation(A*256)+B)/8
The small o in front of the F=degrees
Old Aug 16, 2013 | 08:59 PM
Quickfords's Avatar
Quickfords
Trailering
This looks like the PID that I have, but its just not reading temp.
brannman
May 24, 2019 06:09 PM
tfunk88
Jan 4, 2018 04:42 PM
coachvassar
2009 - 2014 F150
May 16, 2017 11:03 PM
WatsonR
Jul 8, 2014 09:58 PM
emptyd
Jun 11, 2007 03:23 PM
