Fuse Box
Old Jan 1, 2018 | 08:56 PM
rolostudio's Avatar
rolostudio
Fuse Box
Hello, my van is 1995 E250,
i have problem, the van does not want to turn me on.
Someone told me that the problem is the fuel pump.
How do i check the fuel pump relay ?
I dont find the schematic for the fuse box .
i alternated the relays but i dont know if are the same for all
thanks so much
Old Jan 2, 2018 | 01:30 AM
Sam I Am's Avatar
Sam I Am
If you have the owners manual, the fuse chart is in there.
Fuel pump relay should be the middle one.
Fuel pump fuse should be H 30A, but I am not certain of that.
If the fuse is good check to be sure the fuel shut off switch has not been tripped. It is located on the right side kick panel under the dash. Make sure the red button is pressed down.
You may want to check for power at that switch. The fuel pump will only run momentarily at key on to prime the fuel rail. Then it is turned off until the engine starts.
Have someone bang on the fuel tank with a clenched fist of rage while trying to start it. Sometimes that will jog a failing fuel pump. If it does, plan to replace the fuel pump ASAP.
Old Jan 10, 2018 | 09:46 PM
rolostudio's Avatar
rolostudio
Hello, thanks for your help,
i dont have owners manual,
but 3 relays are the same ?
i dont remember if i changed the position .
I checked the fuel shut off switch and is pressed down.
Thanks again
Rolando
Old Jan 10, 2018 | 11:32 PM
Sam I Am's Avatar
Sam I Am
Here is a link to a 1996 E250 owners manual:
http://www.fordservicecontent.com/Fo.../96ecoog1e.pdf
That is as far back as that site goes.
I'm not sure on the relay ratings. If they are the same part #, it is the same rating. It is possible for a relay to burn out, but it is more likely that the fuel pump is dead. Check for power at the fuel cut off switch with it connected, check it at the moment someone else turns the key to run.
fordexplorersport
Feb 11, 2016 06:55 AM
renchr56
Oct 2, 2009 06:26 PM
gr411
1997 - 2003 F150
May 25, 2009 01:19 AM
toyota1988
4 Cylinder Engines
29
Jul 10, 2007 06:23 PM
jon_boy
Aug 19, 2004 07:44 AM
