Fuse Box
3 Attachment(s)
Hello, my van is 1995 E250,
i have problem, the van does not want to turn me on. Someone told me that the problem is the fuel pump. How do i check the fuel pump relay ? I dont find the schematic for the fuse box . i alternated the relays but i dont know if are the same for all thanks so much |
If you have the owners manual, the fuse chart is in there.
Fuel pump relay should be the middle one. Fuel pump fuse should be H 30A, but I am not certain of that. If the fuse is good check to be sure the fuel shut off switch has not been tripped. It is located on the right side kick panel under the dash. Make sure the red button is pressed down. You may want to check for power at that switch. The fuel pump will only run momentarily at key on to prime the fuel rail. Then it is turned off until the engine starts. Have someone bang on the fuel tank with a clenched fist of rage while trying to start it. Sometimes that will jog a failing fuel pump. If it does, plan to replace the fuel pump ASAP. |
Hello, thanks for your help,
i dont have owners manual, but 3 relays are the same ? i dont remember if i changed the position . I checked the fuel shut off switch and is pressed down. Thanks again Rolando |
Here is a link to a 1996 E250 owners manual:
http://www.fordservicecontent.com/Fo.../96ecoog1e.pdf That is as far back as that site goes. I'm not sure on the relay ratings. If they are the same part #, it is the same rating. It is possible for a relay to burn out, but it is more likely that the fuel pump is dead. Check for power at the fuel cut off switch with it connected, check it at the moment someone else turns the key to run. |
