Srod shifter saddle replacement
I can't find anything on replacing the shifter saddle/bushing on this transmission if anyone has done it could you please chime ln is it simple as pull shifter out snap old part out snap new part in or is there a certain procedure to it ???
1981 ford f100 4.9l srod manual trans 2wd |
Originally Posted by FirstFord1994
(Post 17686784)
I can't find anything on replacing the shifter saddle/bushing on this transmission. If anyone has done it, could you please chime in.
Is it simple as pulling the shifter out, snap old part out...snap new part in, or is there a certain procedure to it? 1981 F100 4.9L with RUG SR-OD Single Rail 4 Speed Overdrive. AFAIK, all you have to do is remove the shift lever, remove the broken pieces (a common problem!) of the old bushing, replace with new. D9BZ-7K453-B (replaced D9BZ-7K453-A) .. Gearshift Dampener Nylon Bushing / Obsolete 1979/82 Granada; 1979/83 Mustang/Capri/Fairmont/Zephyr; 1980/83 F100/250. https://cimg6.ibsrv.net/gimg/www.for...a688615868.jpg |
Thanks for all the help all fixed shifts smooth as butter now
(Post 17723472)
Where did you find a new one or did you make something to "fit in"? Dave ---- |
Found 1 on eBay just searched srod shifter saddle and it came up
Thanks for answering as it may help others.
Dave ---- |
it was the 1.5" srod shifter saddle i put it in with the square part on the right hand side when you are facing dash hope this helps someone
https://www.ebay.com/itm/SROD-RUG-RT...xVBMSp&vxp=mtr |
