2017 rims on a 2000
Old Dec 28, 2017 | 10:03 AM
shamrock442's Avatar
shamrock442
2017 rims on a 2000
What all would I need to do in order to run late model rims on my 2000 f350 super duty. Would I need to run a spacer plate? Any help would be greatly appreciated. Thanks Mike
Old Dec 28, 2017 | 10:17 AM
Njstern87's Avatar
Njstern87
I have heard two inch hub centric spacers, but I'm not 100% positive. Want to do the same thing to my 99, subscribing.
Old Dec 28, 2017 | 10:22 AM
Dan V's Avatar
Dan V
Spacers and differing bolt pattern I seem to recall.
Old Dec 28, 2017 | 10:46 AM
mecdac's Avatar
mecdac
Exclamation
Bolt pattern is the same, the offset is different. That is why you'd need spacers.
Quality hub centric spacers will cost $600-$800.
A better option (IMO) is find 2004 18" wheels in the SVT or Harley-Davidson or Lariat variety.
Some reading material: https://www.ford-trucks.com/forums/1...l#post16064812 and https://www.ford-trucks.com/forums/1...l#post16431273 .
Old Dec 28, 2017 | 11:07 AM
cjfarm11's Avatar
cjfarm11
Yes a good set of hub centric 2” spacers. I’m running them on two different vehicles and zero issues. But I did buy the expensive ones and they are steel not aluminum if that makes any difference? I don’t know
Old Dec 28, 2017 | 11:12 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The 18" 03-04 Harley wheels are sexy but expensive and sort of rare. The 18" Lariat wheels look similar but don't have all the fancy machine work.
2" spacers are required (1.76" precisely but stud trimming is mandatory with spacers less than 2" thick) to run 05-present F250/350srw wheels on a 1999-04 pickup. I've used spacers for wheels on a few vehicles, one currently a 2000 with 2005 20" wheels.
Old Dec 28, 2017 | 07:33 PM
F350-6's Avatar
F350-6
As mentioned, either get a set of spacers, or don't plan on turning too sharp.
I thought you had to cut down the studs even with 2" spacers, but Cody probably knows better than I do. Son in law had an excursion with spacers. Thought they were 2" but could have been 1.75" or something. We had to cut the studs on that one.
Keep in mind that the thread is different on the 05 and up models, so be sure you know which studs come on your spacers and don't mix lug nuts from the old generation with the new ones.
Airborne-F250
Feb 15, 2019 03:16 PM
Hossrod
Sep 24, 2018 10:33 AM
the deno
Apr 27, 2008 05:45 PM
Hellonwheels
Jan 19, 2008 08:09 AM
omni
General Automotive Discussion
Dec 14, 2004 09:12 AM
