Rims
Old Jan 17, 2008 | 06:27 PM
Hellonwheels's Avatar
Hellonwheels
Rims
I have a 92 Ford f-350 that im dressing up. I want to get some 19.5inch chrome rims. Does anyone make rims for my bolt pattern. Im pretty sure the newer trucks are metric. Any help is appreciated.
Old Jan 17, 2008 | 09:24 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The hub bolt circle diameter changed on the 1999 F series.
Any wheel made for the 8 lug Ford before 1999 should fit.
You are looking for a 6.5 x 8 wheel bolt pattern.
6.5" bolt circle 8 lug
There are several people that carry the larger diameter wheels in the old bolt pattern, but most of them seem to be very proud of the wheels.
Also when looking, do check the load rating.
I have seen 8 lug truck wheels with load ratings down as low as 2000 pounds.
Yes they look nice, but if you put a load on the truck they may fail.
Dodge wheels will usually fit as well, but the center hole on a Chevy wheel will not clear the hub.
Old Jan 19, 2008 | 08:09 AM
fonefiddy's Avatar
fonefiddy
Your prolly going to want to buy the whole wheel? Rims are hard to bolt onto a truck, without the hub.
Get ready for some sticker shock! 19.5 wheels, and tires run $3000-5000.
http://www.southwestwheel.com/fordmaxforce.htm
16" wheels are a more economical choice. Iv'e got a set of Alcoa LTS's and loveum!
http://www.southwestwheel.com/wheels/alcoa/167031.htm
MikeL67
Projects
Jan 24, 2016 04:25 PM
bruali
Aug 8, 2012 11:30 PM
lakewood
Sep 17, 2011 10:02 AM
the Goat
Aug 27, 2010 10:35 PM
thepitshop
Mar 9, 2009 11:33 AM
