Yes. On a reader at the driver side port. Cleared fault and it recurred about ten minutes later.
I could not find the 1640 code in the look up provided elsewhere on this site. I want to make sure I have some idea before I trot it back to dealer.
ps merry Christmas.
Went to dealer, they replaced both o2 sensors on exhaust. Drove home, life was good. Put fuel in, light back on.
crawled under truck and see what looks like a sensor just down stream of the exhaust system, but it looks original.
im suspecting they cleared codes, reset cel, called it good.
P1640 - Ford
Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
Description
PCM Trouble Codes Available in Another Module Conditions
Cause
Key on or engine running and the PCM received a request from another module to illuminate the MIL due to a fault that could affect emissions Scan Tool Tips Request PID 0946 to determine which module failed
