Testing DEF and coolant/battery
Old Dec 21, 2017 | 06:39 PM
First time 5ers's Avatar
First time 5ers
Was looking into refractometers to check coolant and batteries but was also interested in checking DEF fluid quality. Anybody know if a standard coolant/battery refractometer can be used to also test DEF? Or do I need a DEF specific instrument?
Old Dec 21, 2017 | 07:00 PM
senix's Avatar
senix
why even bother testing the def? Put it in and use it. when you are down to less than 200 miles to empty, refill it.
Don't buy a bunch of it and store in in moderate temps if you buy some extra.
Old Dec 21, 2017 | 07:40 PM
17superduty's Avatar
17superduty
There is a def tester that is like an antifreeze tester. Has 3 pucks inside. If 2 float your def concentration is right at 32.5 or ideal.
A refractormeter for def is specific and has the 32.5 % line clearly marked
Def quality is a different chemical test. It tests for impurities
Old Dec 21, 2017 | 07:55 PM
First Dually's Avatar
First Dually
Measuring DEF concentration can easily be done...but I don't understand what will be gained from the data. Presumably it will test 32.5% +/- concentration (I have no clue what is an allowable range.)
Measuring other parameters as an indication "quality" would likely take more equipment than we enthusiasts would have access.
I have a quality digital hand-held refractometer. When my SD is delivered I test some DEF as it is added to the truck for grins. But I'm thinking buying/using fresh DEF assuming it is OK is going to work just fine.
Old Dec 21, 2017 | 08:31 PM
First Dually
Some more info...this from the manufacturer of the refractometer I have.
Old Dec 21, 2017 | 09:56 PM
HRTKD's Avatar
HRTKD
I have a hydrometer for my batteries. It's mainly for my trailer batteries. It worked well to confirm that I had a bad cell. I don't know if this is common to all hydrometers but mine is glass and I've had to store it away very carefully. It would be very easy to break it. I don't store it in the trailer.
If you get AGM batteries then you have no need for a hydrometer.
As far as testing the DEF goes, I have to say it is refreshing to find someone more OCD than I am.
There are coolant test strips that you can buy from Acustrip. I think the owner's manual will tell you the specific version to buy.
steveg_nh
6.7L Power Stroke Diesel
22
Mar 7, 2021 10:02 AM
2civicrr
18
Jan 5, 2017 05:16 AM
W7PSK
73
Nov 21, 2015 02:49 PM
pawpaw
1983 - 2012 Ranger & B-Series
17
Oct 17, 2015 11:36 PM
Chad149
42
Apr 6, 2013 11:04 PM
