Transmission swap
Old Dec 21, 2017 | 05:20 PM
Larry5501's Avatar
Larry5501
Transmission swap
Will a c6 transmission replace a c4 transmission in a 1972 long wheel base ford f 100 without modifications.
Old Dec 21, 2017 | 08:06 PM
RichS2659's Avatar
RichS2659
You say you have a C-4, so you must have a 240/300, or a 302 and it is 2wd. The C-4 can be exchanged for a C-6, but IIRC, the C-6 is about 11" longer, or thereabouts. You will have to shorten the driveshaft the required amount, or find a C-6 shaft, and the shift linkage might have to be exchanged for an FE C-6 set. The SBF pattern C-6 can be found in 80's trucks and Econo's. Why do you want a C-6? If going to that trouble, why not go OD with an AOD, or with an electronic controller-controlled AODE/4R70W. If you still want the strength of the C-6, step up to an E4OD/4R100.
Old Dec 21, 2017 | 08:20 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Rich is not wrong, but.....
Tell us what engine you have. C4 is typically a small block tranny and a C6, well it varies but is usually for a big block or FE engine.
If you have a small block, O/D tranny will be the way to go.
Old Dec 21, 2017 | 08:30 PM
Larry5501's Avatar
Larry5501
Transmission swap
The 1972 ford 100 has a 1984 351w motor according to the block number.
Old Dec 21, 2017 | 08:41 PM
TeachNlive4ever
I’m not the trans guru, but others here are. I would encourage you to run an overdrive trans. There are a few that have em and work and run the hell out of em.
Old Dec 21, 2017 | 10:09 PM
kenny nunez's Avatar
kenny nunez
Exclamation C4-C6-AOD
You will also have to re-plumb the cooler lines.
Old Dec 22, 2017 | 12:06 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978 was the first year that the C6 was available with 300/302, but the C4 was also available thru 1981.
AOD introduced in 1981 F100/150 300/302.
Old Dec 22, 2017 | 01:26 PM
Freightrain's Avatar
Freightrain
They do offer a C6 with a small block bellhousing. It will physically bolt up, not sure what all you might have to adjust to make everything hook up?
Old Dec 22, 2017 | 01:37 PM
MIKES 68 F100's Avatar
MIKES 68 F100
hard to find the small block C6
go with the AOD
Old Dec 22, 2017 | 02:16 PM
kenny nunez
Swap
I once replaced an AOD with a C6 on a 86 Crown Victoria. I also had to replace the fly wheel because there is supposed to be a different off set.
The Ford parts guys on this site should be able help with this.
Old Dec 22, 2017 | 06:25 PM
TeachNlive4ever
go with the AOD
2X and 3.73 (ish) rear gear
Old Dec 23, 2017 | 09:37 AM
kdaug5's Avatar
kdaug5
i did the AOD swap about a year ago. Used one from a Tbird. It works great behind my 351W and 4.11s
Old Dec 23, 2017 | 10:02 AM
351Cleveland C4's Avatar
351Cleveland C4
Been running mine for a couple years now. Same thing. 4.11 gears really complement the OD if you're running tall tires. 31"
kentruckf100
Oct 1, 2014 08:58 AM
LarryH1
Sep 24, 2010 04:11 AM
jbmolly
May 8, 2004 11:04 PM
99Motorcraft
Aug 24, 2003 10:02 PM
CT
Jul 4, 1999 12:54 PM
