Rear view mirror and sun visor bracket color
Sun visor arms and the support stub on the other end that came with the visors were typically the argent (silver). I have not seen any exceptions to this myself.
Here's some NOS ones - look the same as any others I've seen.
C1TZ-8104144-A - RH Visor Arm and Bracket Assembly - 1 each
C1TZ-8104145-A - LH Visor Arm and Bracket Assembly - 1 each
The support stub on the inside ends of the visors came with the visors, whether the standard visor like these or the padded style. Again, argent in all cases I've seen.
The visor arm clips I've seen typically in the same argent, and that's what I will paint mine. But, occasionally there are some, like the mirror below, sort of a beige like this one.
C1UZ-8904132-A - Visor Pin Clip - 2 each max.
The mirror could have been a sort of beige. If not this then, you guessed it, argent again.
C1TZ-17700-A - Rear View Inside Mirror Assembly - 1 each
They all used the same screw.
52369-S13 - Screw-oval head, cross recess-No. 10-12 x 7/8" (chrome)
3 or 6 on the visor arms - 6 assuming two visors
1 or 2 on the visor pin clips - 2 assuming two visors
3 on the inside rear view mirror
7 or 11 total per truck.
They came in boxes of 144. Would have been enough for, at most, 13 trucks with one spare. This screw was not used anyplace else on our trucks.
Chad
Chad
Chad, Thanks again. I was hoping I didn't ask the same question twice AGAIN ! LOL . My mirror seems to have the beige color while the visor brackets and clips seem to be argent. This is why I asked the question and you covered both. I think I'll soda blast both and probably go with argent. Thanks again.
Sam's1967
06-05-2016 04:03 PM
raytasch
02-14-2014 07:56 PM
68horses
16
01-21-2009 11:02 PM
