352 valves
Old Dec 20, 2017 | 07:07 PM
jwitty's Avatar
jwitty
352 valves
So took the valve covers off my engine. Looks like everything has a nice coat of oil. Now...i know these rocker arms are non adjustable. But, how do I tell if the tolerances aren't right. I did jiggle each push rod and almost all of them were tight except 2 of them. What would this mean?
Old Dec 20, 2017 | 09:18 PM
1972RedNeck's Avatar
1972RedNeck
They should all have pressure on them as they are hydraulic lifters. If any of them have "lash" you have a problem...
Old Dec 20, 2017 | 09:21 PM
jwitty's Avatar
jwitty
could it make a knocking noise? I heard from other people that fe engines seem to bend push rods a little easier and when they are bent it causes a knockingish sound
Old Dec 20, 2017 | 11:04 PM
mrpotatohead's Avatar
mrpotatohead
Are you hearing a ticking sound?
Old Dec 21, 2017 | 07:03 AM
jwitty's Avatar
jwitty
there is a slight ticking noise also but there is also manifold leaks. (I've found 2 so far)
Old Dec 21, 2017 | 07:04 AM
jwitty's Avatar
jwitty
But so I get this straight. At no time should the push rod be loose on the rocker correct?
Old Dec 21, 2017 | 07:52 AM
jwitty's Avatar
jwitty
so went out this morning and jiggled all the rocker arms and push rods. On #5 cylinder one of the rockers I can move back and forth on the rockshaft or whatever that shaft is called
Old Dec 21, 2017 | 08:54 AM
1972RedNeck
You can rock it back and for with ease? That is bad - very bad...
Old Dec 21, 2017 | 09:00 AM
jwitty's Avatar
jwitty
yep I can. If I can upload videos of it on here I will. What does this mean? And would it cause a slight knocking sound?
Old Dec 21, 2017 | 11:39 AM
TheMonson's Avatar
TheMonson
You can upload to YouTube and link it here.
Old Dec 21, 2017 | 11:40 AM
jwitty's Avatar
jwitty
alright I'll see if I can do that tonight
Old Dec 21, 2017 | 02:07 PM
Crop Duster's Avatar
Crop Duster
Rocker shaft
The shop manual says the clearance between the rocker and the shaft is .002 to .005 with the wear limit at .006. You shouldn't be able to wiggle anything. How many miles are on that engine?
Old Dec 21, 2017 | 02:57 PM
jwitty's Avatar
jwitty
good question lol. Not positive but I think 200000. I know it's ready for a rebuild. I will eventually do one.
Old Dec 21, 2017 | 06:22 PM
jwitty's Avatar
jwitty
Well looks like the video won't be happening lol. Decided to just start tearing the top end down. I got as far as getting the driver side head off. Things are looking pretty good. Looked like someone was in the engine before me. There were newer gaskets. And I can definitely tell why I had a manifold leak lol. Really bad gasket. I'll send some pics when I can. The only thing I noticed was that one cam lobe almost looked like it had like a flat spot on it. Maybe it was the light reflecting off it not too sure. I will be getting a new cam and lifters. Does anyone have any recommendations on one preferably under 200. Thanks
Old Dec 22, 2017 | 12:59 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/67 F100/350 352:
C4TZ-6565-B .. Pushrod-Standard: 9.62" O/A length.
C8AZ-6565-A .. Pushrod: .030" U/S - 9.59" O/A length.
C4TZ-6565-C .. Pushrod: .060" O/S
C4TZ-6565-D .. Pushrod: .060" U/S
tomcasino
Dec 27, 2017 03:26 PM
HighboyHugger
Nov 3, 2013 01:53 AM
Hellbore
24
Jun 5, 2006 02:12 PM
66beater
Jun 3, 2005 03:01 PM
youn3500
Feb 1, 2005 02:17 PM
