Brake Question
Old Dec 20, 2017 | 04:28 PM
Wolfhound11B's Avatar
Wolfhound11B
Brake Question
Hi,
I pulled a 1993 F150 4x4 out of a ranchers field and have been working on getting it road worthy. Its on the road now but after sitting for years things are starting to show that they need to be replaced. The brakes have to be done and I am wondering if any of you have done the conversion to disks in the back? If so can you recommend a kit or is it cheaper to get the parts together myself?
Here are a few pics of the truck. One if of how it looked when it came out of the field and the others are where it is at now.
Its going to be used for hunting and going to the local Home Depot and that is about it. It has a rebuilt motor (1000 miles ago) but needs some more work to get it where I want it.
Old Dec 20, 2017 | 09:39 PM
Willigaf's Avatar
Willigaf
There isn't a good solution for a parking brake as of a month ago when I talked to Ruffstuff. If their kit is the same for a 8 3/4 as it is for the sterling you get 1 ton GM front calipers, 1 ton E series rear rotors, the brackets, and some rubber lines. You can probably piece it together cheaper but if you wait til they have a sale, probably for Christmas, they'll be like 20% off prob.
Toss a wheel chock in the bed and voila.
On the other hand, it will be cheaper to make your brakes work, and if it isn't a race car, you should be fine. Is there a problem, or you're just looking at the options?
Looks nice by the way. And welcome
Old Dec 20, 2017 | 10:12 PM
Willigaf's Avatar
Willigaf
Checked the Ruffstuff website and they might not have anything for your axle.
Old Dec 20, 2017 | 10:33 PM
westcoasting's Avatar
westcoasting
What exactly are you hoping for with the disc conversion over just replacing the worn existing parts?
Old Dec 20, 2017 | 10:37 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
I would advise against a disc conversion unless you plan on towing - the benefits of a disc vs drum are not worth it unless you tow with this thing - a lot.
Old Dec 21, 2017 | 04:07 AM
My4Fordtrucks's Avatar
My4Fordtrucks
For your intended use the drum brakes are more than adequate. The truck is 5 lug so I'm assuming it still has the 8.8 and doesn't have a Mopar 8 3/4 or Sterling rear. A quick glance at the SummitRacing site shows 43 listings.
Old Dec 21, 2017 | 05:32 AM
Wolfhound11B
Thanks all
Basically you guys answered my question and thank you for that. The truck has 200k miles on it and the brakes need to be replaced. The rear right drum is leaking fluid and the rest of the braking system is pretty rusty. This truck was abused and even though it looks ok there are some things that need to be addressed. If I tow it will be my small 1958 Feathercraft aluminum boat. No more than 1000 pounds. It sounds like parts could be an issue so refurbishing the current set up with an available kit makes the most sense. I have 3 major repairs left to complete (this being one of them) to get the truck where I feel comfortable with it as a daily driver so saving money on the brakes is a good thing. Thanks again all. I appreciate the input.
Old Dec 21, 2017 | 09:21 AM
Willigaf's Avatar
Willigaf
My bad with Chrysler reference. Only had a half ton a few weeks and left all the non 8 lug info in the past with my last 150 a long while ago.
Old Dec 21, 2017 | 09:33 AM
My4Fordtrucks
Replacing the lines with a pre-bent kit (OEM or SS) or even making your own lines plus replacing the drum art with new components would be cheaper than or about the same price as the price conversion kit.
BGF100
Feb 26, 2017 09:52 AM
93 Blue Z32(NC)
Large Truck
Nov 19, 2016 08:54 AM
pit_of_pity
Jul 12, 2011 01:53 PM
RicManSr
Jul 8, 2009 09:34 AM
Phantom4WD
Jun 25, 2008 12:39 AM
