Tornado Fuel Saver?
Old Oct 19, 2001 | 03:59 PM
mcdev's Avatar
mcdev
Tornado Fuel Saver?
Hey there fellas. Been a while since I last posted, but I have a question for all of you. Saw one of those infomercials about this Tornado Fuel Saver. You put it in the intake hose in the truck and its supposed to increase fuel economy and horsepower. Have any of you tried this thing or looked into it? If it does what it says, for $70 it may be something to consider... Here is their website, www.tornadofuelsaver.com. Thanks,
Barry
PS. Oh yeah, let my girlfriend drive my truck once and she dented the hell out of the front right side. Does anyone know where the best place to get a new panel, "Nite" decals and the F150 emblem? Thanks...
1991 F150 Nite, 5.8L, E4OD, K&N Filter Charger... 180+K and still going strong
"That ol' Fords sure fast on the draw / out gun the Chevys and out run the law" -Brooks and Dunn "Days of Thunder"
Old Oct 22, 2001 | 06:35 AM
TallPaul's Avatar
TallPaul
Tornado Fuel Saver?
Old Oct 22, 2001 | 10:20 AM
jim henderson's Avatar
jim henderson
Tornado Fuel Saver?
I cannot speak specifically about this product but I can parrot back what I have read and heard in over 30 years of tinkering with cars for fun.
"None of these miracle widgets works" is the basic statement I have heard over and over through the years. Afterall, with all the pressure on Detroit or the imports to improve gas economy or face stiff penalties and "Luxury" taxes, don't you think the automakers would jump at a $70 product that will significanly increase their mileage claims?
Most of these products rely on several of the following characteristics to work. 1) Gullibility; 2) Most people don't return products that have a money back guarantee; 3) The amount of actual gain if any is basically in the noise level or error in record keeping; 4) How do you really prove they work? I get variations in mileage of between 1-3 mpg on my routine driving, so a product improving gas mileage by 1-3mpg would probably get lost in the noise.
There are actually a few products that kind of work, but not for the reasons they give, and usually only in an engine that isn't running properly. Like the good old tried and true Spark Increaser or something named like that. It was a thing about the size of a film can that sat ontop of your ignition coil. It supposedly increased your spark. In actuallity it really did work, but like I said not for the claimed reason. What this product was, was a empty plastic case that had a spark gap inside. The spark gap forced the ignition coil to generate a higher voltage spark so it could jump the gap in addition to the sparkplug gaps. It worked in engines that were running poorly due to something(oil, wornout wires, poor fuel mix) fouling the plugs or causing a need for higher voltage. It did nothing for engines that were running fine, except to stress the coil. The problem is that if the coil is unable to generate the extra voltage, then the plugs don't fire. So yes it works, but you could get the same effect for free by pulling the spark wire out of the coil a bit, an old mechanics trick.
If one of these products had a real test lab testimonial with documentation, then I would look at them. If the testimonial is Joe Blow, who is just astounded at the incredible mileage gains he got, well I just keep thinking to myself that Elvis is alive and working at Burger King too according to testimonials.
Give me unbiased, name brand laboratory proof, then lets talk money.
But if you want to spend $70, I suppose it is OK, it helps the economy.
Quote I read in the 70s, "Why, the way I figure, if I added all these gas savers, I would have to stop every few miles and dump some gas out."
Good Luck,
Jim Henderson, skeptic to the last.
Old Oct 23, 2001 | 07:15 AM
TallPaul's Avatar
TallPaul
Tornado Fuel Saver?
Why not get a K&N air filter or filtercharger (whole intake assembly? They provide freer air flow which should help fuel mileage.
Old Oct 23, 2001 | 08:24 AM
FTE Ken's Avatar
FTE Ken
Tornado Fuel Saver?
The EPA's test of the Tornado shows no increase in mileage.
Ken Payne
[img src="/dcforum/User_files/webmaster/usaflag.gif" valign=top align=left] Ford Truck Enthusiasts Admin
Old Oct 24, 2001 | 03:55 PM
cactus_jack23's Avatar
cactus_jack23
Tornado Fuel Saver?
I have a 1992 F150 4x4 regular cab 302 (5.0 L)
anyway I've been having a problem with the front tank not reading on my gas guage; I'm wondering what gives with it any one had the same problem? This happened before when it was New I took it to the dealer that was 8 years ago now I have the same problem again most of the time it reads 1/4 of the tank , and that's when I have filled it up! HELP!!!!!
Ps The Guage works fine on the back tank!
When I win the Lottery Of course I'll quit me job,
I'll be rich not crazy.
Old Oct 24, 2001 | 05:52 PM
gamehunter's Avatar
gamehunter
Tornado Fuel Saver?
Hey, Cactus_Jack, I have the same problem with mine. When I bought the truck in the spring I was driving on the rear tank which reads correct. I was getting down to 1/4 tank but I knew I had a whole front tank left. I went to work one day which is 30 miles away, on the way home I decided to switch to the front tank rather than let the rear go dry. When I flipped it over to my surprise it went down to 1/8th tank or less. Ok, now what am I gonna do? Luckily my grandparents live close by so I swong in there and borrowed 5 gallons of gas to get me home. So I decided to run on the front tank just to see what happens.
I figured the float in the gas tank must have sank or something because now it reads just over "E". All I do is run on the front tank for approximately 200 or so miles in town and then I switch to the rear tank. That way I always know I have gas left. But as to how to fix it, I don't know.
'90 1/2 ton 4x4 XLT Lariat
RC LB w/5.0 EFI M50D 3.73gear
true duals w/glasspacks
kenworthfan
Sep 14, 2007 06:12 PM
stang3O2
1997 - 2003 F150
18
Apr 11, 2005 07:26 PM
adamsre
General Automotive Discussion
Mar 29, 2005 11:40 AM
1big79
Dec 7, 2003 05:08 AM
TonyG
Aftermarket Products
13
Mar 24, 2002 05:43 PM
