BACK UP CAMERA ISSUES
Old Dec 19, 2017 | 11:25 AM
SliderF150's Avatar
SliderF150
I have a 2016 F150 FX4 and the camera recently stopped working with only a blue screen showing with the small truck pic showing in the upper right corner for the back up sensors. This occurred just after a car wash on a cold day ( below freezing) .Any thoughts ?
Old Dec 19, 2017 | 11:46 AM
JKBrad's Avatar
JKBrad
Find where the tailgate harness plug is. It probably wasn't fully seated when it left the factory (this is not uncommon, for all wiring harnesses on a vehicle BTW). Pull it apart, spray some WD40 in both sides, smear a little dielectric grease on it then snap it back together, make sure it's fully seated.
Old Dec 19, 2017 | 11:52 AM
SliderF150's Avatar
SliderF150
what general area should I be looking for the plug in ? ( I have the tailgate step btw if that matters ?)
Old Dec 19, 2017 | 12:02 PM
JKBrad's Avatar
JKBrad
It should be center, below the tailgate. If you can't find it, look in the owners manual, as the tailgate is designed to be easy to remove.
Don't smear the dielectric grease on the metal,parts of the terminals, just the rubber seal and the outer parts that clip together. Just a small amount on a Qtip should do.
Old Dec 19, 2017 | 12:04 PM
SliderF150's Avatar
SliderF150
gotcha...I'll try that !
Old Dec 20, 2017 | 08:36 AM
SliderF150's Avatar
SliderF150
took a look last night and it is in centre of tailgate bottom. I see several screws on the inside of the tailgate which if I remove should give me access to the camera and hopefully the harness plug without need to remove the tailgate? I doubt my manual would deal with that kind of detail.
Old Dec 20, 2017 | 12:34 PM
JKBrad's Avatar
JKBrad
There should be a plug on the frame. You shouldn't have to take the tailgate apart.
Old Dec 20, 2017 | 12:55 PM
SliderF150's Avatar
SliderF150
the cable appears to go through the back of the truck above the bumper ....plug must be under the truck then as harness just passes through the tail gate and body holes .
Navistar86
Apr 11, 2019 01:35 PM
stvneil
2015 - 2020 F150
Oct 23, 2016 09:17 PM
rvx290
2004 - 2008 F150
Jun 22, 2016 08:10 PM
berry1234
May 13, 2009 10:29 PM
LiverSpots
Oct 20, 2003 11:25 AM
