Lincoln rear disk brakes
on
Back in the '90s I used a '75 Lincoln Mark IV rear end... 9" with disc brakes.
Now I'm trying to put the disc brakes back together and my memory is somewhat fuzzy... I can't seem to get all the pieces together with two hands, insert it into the caliper bracket and slide the wedge and spring into the slot and hammer it in before bolting it...
My main problem is the inboard pad doesn't have anything that holds it in place until it is actually in place... and my fat fingers just won't work they way they need to to do this., so I must be missing something
Anyone with any experience with these Lincoln brakes ??? It's not the Versailles rear... just a Mark IV... I'd love to find a step by step like in a Motor manual.. I need to lead by my bit sometimes.
I'll get some pics taken today
thanks
John
thanks
John
Back in the '90s I used a '75 Lincoln Continental Mark IV rear end... 9" with disc brakes.
Yes, but they are hard to get in there straight. Just use slight pressure, and push from top bottom same time, or clip will pop off
on
yea... I know... having trouble keeping it in place when installing the caliper and realized that i needed the anti-rattle springs to hold it... but that pad in the diagram doesn't resemble mine... mine is smooth on the back without the ring thing... can't seem to find an example like that on the net
Ring thing is probably factory Ford. Long gone, forever forgotten
That would have set in/on the cup of the caliper
The aftermarket pad will be smooth, just like the outside pad
Once you hit the brake pedal for the first time, and "set" the pad in place on the rotor, the gap will be filled
cusz721
08-04-2019 07:33 AM
morepower16
01-21-2004 03:58 PM
