Steering column
Old Dec 19, 2017 | 12:51 AM
1999stroke's Avatar
1999stroke
Steering column
I am thinking of replacing the steering column in my truck for one that tilts I would like to keep the key on the dash what are you guys using for your swaps
Old Dec 19, 2017 | 07:17 AM
ultraranger's Avatar
ultraranger
1978/'79 F-series trucks were the first year models available with a tilt wheel column. The key wasn't on any of the truck columns until 1980. These columns were also optionally available in the '78/'79 full-sized Broncos and E-series vans --the column from a van will be longer than one from a truck/Bronco.
Most are configured for an automatic transmission with the shift selector lever on the column. Some were configured for a floor shifter with no gear selector lever on the side of the column but, these are few and far between.
The gear indicator dial is also lighted on the tilt column, when you turn your head lights on.
You'll have to have a Saginaw power steering gearbox to couple the column to.
I have a tilt wheel column from a '78 F150 in my '69 F100.
Fordification tech article on installing a tilt wheel column.
How to Install a Tilt Steering Column - FORDification.com
Old Dec 19, 2017 | 07:47 AM
orich's Avatar
orich
I've heard (hear say) that there is no replacement u-joints for the upper tilt shaft assembly so if your still wanting to use a Ford column keep this in mine.
I was at one of the Good Guys car shows a couple of yrs ago an, I asked one of the vendors that was selling the tilt type that would fit my 71 F250 with key on dash floor-shift type if the u-joints were replaceable an he said they were.
Just a heads up before you buy one..
Orich
Old Dec 19, 2017 | 10:53 AM
TeachNlive4ever's Avatar
TeachNlive4ever
2X on the 79.
Old Dec 19, 2017 | 12:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by orich
I've heard (hear say) that there is no replacement u-joints (no such thing) for the upper tilt shaft assembly so if your still wanting to use a Ford column keep this in mine.
Pic: Where are the u-joints? No see um.
Most of the tilt parts are the same: 1970/79 FoMoCo Passenger Cars; 1978/91 F100/350, Bronco & Econoline; 1980 Granada/Monarch/Versailles.
The part that is almost impossible to find is the tilt wheel locking lever (3B661 in pic). I know where there's ONE (found it @ a dealer in OK last September). No one else has any.
Old Dec 20, 2017 | 08:09 AM
pchelp's Avatar
pchelp
I ordered my floor shift tilt column from Ididit, not cheap $800 plus
Old Dec 20, 2017 | 09:06 PM
TeachNlive4ever
PC, how did you get passed the diameter difference with the lower bracket?
Old Dec 20, 2017 | 10:54 PM
HIO Silver's Avatar
HIO Silver
The cost could knock off a couple of hundred bucks or more if ya opt for a bare steel column and paint er up.
Old Dec 24, 2017 | 08:00 PM
pchelp's Avatar
pchelp
This particular column was specifically built by Ididit to bolt directly in. Even the wiring was OEM color coded, hence the high price tag and extended build time wait. My only complaint is the turn signal cancellation doesn't work.
Old Dec 24, 2017 | 08:09 PM
pchelp's Avatar
pchelp
Give me a wrench and socket set and I can do just about anything, when it comes to spraying paint without running it I'm useless
Old Dec 24, 2017 | 08:14 PM
orich's Avatar
orich
The little clamp on bracket on the under side of the steering wheel hub may be missing or not timed right.
Orich
Old Dec 24, 2017 | 08:26 PM
pchelp's Avatar
pchelp
Orich
Next time I pull the wheel I'll have to check it out
Old Dec 25, 2017 | 07:54 PM
TeachNlive4ever
I recall the column being too small in diameter. Did you get another?
Old Dec 25, 2017 | 08:33 PM
pchelp's Avatar
pchelp
Yep, sure did. Sold the first one on eBay
Baby Boomer
Apr 26, 2017 01:09 PM
Bossbronco
Nov 24, 2014 05:07 PM
mamelukesword
13
Jan 20, 2007 04:05 PM
gatoraid
Sep 21, 2006 08:35 PM
Headman
Aug 26, 2004 09:00 AM
