steering column
I believe tilt was only (optionally) available on the higher end models.
You will either have to have an automatic transmission or a manual with the shifter in the floor. The tilt didn't come with manual shift on the tree.
A number of critical parts for the tilt column are not available new so, whatever column you may find, make sure the tilt mechanism is in good shape.
I recently installed a tilt column (for an automatic transmission) and a Saginaw power steering gear box in my '69 F-100, that came out of a '78 F-150.
How to Install a Tilt Steering Column - FORDification.com
How to Install Power Steering in a 2WD F100/250/350 - FORDification.com
My tilt column.
https://www.ford-trucks.com/forums/1...t-drums-4.html
