What tilt column have you guys used?
My truck originally had manual steering with the stock fixed steering column for an automatic transmission. I installed a tilt wheel column that came from a '78 F150.
1978 and 1979 were the only two years in the Dentside era these columns were available and they were optionally available in the trucks, vans and Broncos. I believe the tilts in the vans possibly had longer column tubes and shafts, compared to the trucks or Broncos.
....well, that's not totally true. When I got my column, it was missing the bolted clamp/flange at the lower end of the shaft. With this part missing, I had no means of coupling to the rag joint.
Needed bolted flange shown here --the piece my column was missing.
I decided to completely do away with the rag joint and I installed a Borgeson stainless steel steering joint (3/4"-36 spline x 3/4"-36 spline).
The joint is at an angle here because at the time I took this photo, I didn't have the column bolted to the underside of the dash and I was just getting the column/steering joint into position before tightening everything up.
Best I can remember, the e-flasher is controlled off the white wire with red stripe. My switch is still located in the glove box. Someday, I'll run the wire from the column in parallel with the glove box switch and the flashers would be able to be activated either from the glove box or off the switch on the side of the tilt column.
I installed a new TSS for the tilt. Up through '77, the TSS only has one horn contact wire. In '78, they started putting two horn contacts on the TSS switch (tilt or non-tilt). I used one of the contacts for my horn and the other contact will be used to make the cruise control switches functional by sending the signals to the CC module, after I swap engines and install the CC module and servo. --The CC module and servo I have are from a 1990 Mustang GT.
Tilt wheel introduced in 1978 F100/350, Bronco & Econoline. Available with A/T & 4 M/T, not available with 3 M/T
Some of the tilt wheel parts are getting very hard to find.
1975/77: Three different T/S switches: With Speed Control, with M/T, with A/T
1978/79: Three different T/S switches: With tilt wheel, with A/T, with M/T
1978/79's with Speed Control: Horn relay plugs into the Speed Controls amplifier.
No Speed Control, no horn relay.
Sgt Wonderful
04-20-2008 08:54 PM
FE406
03-20-2008 11:56 AM
