Excursion Shift Problem
Old Dec 17, 2017 | 11:48 AM
phillee8286's Avatar
phillee8286
I have a 2000 Excursion 5.4l, the truck wasn't shifting into park and after reviewing the website I came across tightening (2) torx bolts that vibrate loose over time. one bolt was missing so I tighten the one remaining bolt and all seems to be ok at this point but I would like to find where I can purchase a replace bolt so this bracket is 100% secure, does anyone have part # or specs on those shift bracket torx bolts??
Old Dec 17, 2017 | 01:21 PM
Red97350's Avatar
Red97350
Welcome to FTE! You would be better of posting in the Excursion forum for your question. To somewhat answer your question though, your best bet would be to head to a junkyard and pick one up there, or to see if anyone has parted a truck out and saved one of those bolts. I'm going on the assumption that the super duties use the same bolts that the OBS do. Hope this helps.
Red
Old Dec 19, 2017 | 10:31 AM
Misky6.0's Avatar
Misky6.0
Red
Yes, the super-duty '99-'07 have the same torx bolt 'feature'.
Old Dec 19, 2017 | 12:41 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
These look like your missing bolt?
rvpuller
All Things Towing
Jun 16, 2018 11:26 AM
phillee8286
Dec 17, 2017 11:40 PM
bizzelj
Aug 16, 2016 11:24 PM
gator1gear
Dec 23, 2009 05:08 PM
69ford99
1978 - 1996 Big Bronco
Nov 13, 2006 05:07 PM
