Oil Overfill
Old Dec 16, 2017 | 06:28 PM
kcar1981's Avatar
kcar1981
Trailering
Oil Overfill
Should I be concerned that the dealer potentially added an additional quart of oil during the change today? Foaming oil from the crank? When I got home I was looking at the invoice and they charged me for 7 quarts but I only require 6. I have a 2008 v8 Explorer. I usually change my own oil but due to the recent weather in the North East I wasn't able to do it this time around. I will go out in the morning after everything has had a chance to settle over night to check the level. Was thinking if the did overfill it I could change the filter with a fresh one to bring the level down. Thoughts as service isn't open again until Monday.
Old Dec 16, 2017 | 09:46 PM
steve(ill)'s Avatar
steve(ill)
I would check the level first. 1 quart overfull ( if it is overfull) is probably not a real big deal. Maybe 1/4 inch on the stick..... Could be they just added 1/2 quart and charge you for one........... Check Level first.
Old Dec 17, 2017 | 07:06 PM
kcar1981's Avatar
kcar1981
Trailering
Checked the level and it is about a quarter inch over the second hole on the dipstick. Didn't see any foam on the dipstick so I am assuming it is okay but still doesn't make it correct as they should know what they are doing being the Ford dealer and all.
Tawn
6.2L V8
Feb 25, 2017 07:15 PM
madda
2004 - 2008 F150
Jan 25, 2010 02:53 AM
ltatkinson
Modular V10 (6.8l)
Oct 24, 2009 05:16 PM
wildcard30
2004 - 2008 F150
May 17, 2006 11:21 AM
XinOK
Dec 26, 2004 09:57 PM
