Hello all I have the top end of my truck torn aparr. it's a 1991 F250 7.3 I was curious if I want to take the nozzle cap off and do a thorough cleaning of the spring and everything else inside the injector if anybody knows the torque specs for that nozzle cap
Reason: Wrong word and apelling
Have you read up on rebuilding the Injectors? Lot more than wire brushing, blowing them out with air and screwing them back together.
Maybe you are going to do more than that...IDK.
Here is a good video on taking them apart. Doesn`t mention the torque of the 2 halves though.
On my quick Google search didn`t see it for the 2 halves.
How many miles on the Injectors? You can get a good set form R&D Performance for not too much $$$. R&D IDI Performance - Home click on purchase and Injectors.
Yeah I read up on it the only thing I can't find is the torque specs for the two halves that's why I was just throwing the question out there if anybody knew it by chance. I would love to buy new ones or upgraded ones but I'm on a tight budget these days so I have to kind of go old-school and rebuild it it's all possible with what I have here
I was poking around Google trying to find that torque setting. Does not seem to be listed anywhere.
I did find this article on rebuilding them, but this guy could not find the torque either. Good info here.
Thank you guys so much I really appreciate it I was getting frustrated trying to find anything online besides YouTube videos and with work getting ready to permanently close and everything else I just couldn't deal with one more failed internet search. Again thank you it's greatly appreciated
Thanks for the link Charlie. I've thought about rebuilding my injectors. I've rebuilt plenty of carburetors (both GM and Ford), I don't see how diesel injectors could be much more difficult. Definitely something to consider.
You are going to need a pop tester to get them as close as possible when they spray.
That video I posted the guy made his from a Bottle Jack, seen those made over the years. some work good some do not.
Commercially made ones of good quality are pricy. here is a list I found on E-Bay, majority are probably made in China or India by the low price.
Thanks for posting the video too. I watched it and it seems that pop testing the injectors after a rebuild is definitely important. Unfortunately, I don't know if I would have the aptitude to build a tester like that. Here's one available on Amazon:
There are a few others on Amazon that are a bit cheaper. Unfortunately, none of them have numerous reviews.
I searched on the Tool Discounter website. I couldn't find one. They do carry the Ferret timing adapter and a couple of different diesel compression testers. I might have overlooked it:
Pop testing Injectors for your self now and then, the cheaper one`s are probably ok.
You need to have them pop with in 50psi of ea other or what ever it is to have the engine run as well as you can get it.
There is a ton of info out there on how to do it.
The problem will be a source for nozzle and pintle or needle and seat or nozzle as those are the wear items. You'll get some you can clean and shim but our of 8 surely the wear surfaces of some will be marred and pissing fuel. I'm not sure Stenadyne still makes these parts. I believe the two reputable rebuilders (R&D and Conestoga) now do some fancy machine work to refinish the old parts.
I made the mistake of buing one of those pop testers from India; thing takes 20 years to build up pressure and leaks everywhere.
Wait, that's just like my truck...
