2006 6.0l throwing codes
Old Dec 16, 2017 | 11:38 AM
Brad ORourke's Avatar
Brad ORourke
hey gang, my ‘06 6.0l f250 just started to throw a couple codes, p0470, p0676, p0675. And once the engine is warmed up, it doesn’t want to go back to low idle. I know what the codes are, any ideas on plan of attack?
Old Dec 16, 2017 | 11:58 AM
bismic's Avatar
bismic
Eventhough you know what the codes are, I will post the information.
P0675 #5 glow plug circuit
P0676 #6 glow plug circuit
For these codes ohm out the harness and the individual glow plugs
P0470:
"EBP connector problem and /or EBP sensor problem (9.5 times out of 10, a P0470 is solved with a new EBP sensor). Symptoms: Idle surge or flare; surge at cruise, intermittent stall.
Inspect the connector for wear. The P0470 indicates a max value reported to the PCM even at KOEO. It could be a short to power, connector, wiring, or even a PCM issue. TSB 09-24-03 talks about the possibility of a false P0470 code. This code can cause a MAP/BARO correlation code (P0069)."
Old Dec 16, 2017 | 05:13 PM
Brad ORourke
Thanks for the reply
Farmboypowerstroke
Jan 26, 2014 03:25 PM
Joe28443
Apr 21, 2010 09:01 AM
kawa
Nov 29, 2007 05:42 AM
ridgebackphatty
Jan 26, 2006 12:37 PM
