I Don't Have These Codes
Old Nov 28, 2007 | 05:57 PM
kawa's Avatar
kawa
Finally got the beast reunning, It was tough going for a few moments but it finally smoothed out.
CEL came on and I heve these codes, they are not on my sheet of Ford Codes:
03-P1000
02-1395
01-P0475
Plus the wire connector that I couldn't find a home for was the IPR connection.
Rog
Old Nov 28, 2007 | 06:56 PM
ForemanES's Avatar
ForemanES
0475 EPR Exhst press control valve malfunction Exhaust back pressure regulator - KOEO OCC test Open/grounded ckt, solenoid open/shorted, failed PCM
thats the only one I could find for you
Old Nov 28, 2007 | 07:08 PM
MADVAN's Avatar
MADVAN
Cali has glow plug monitor system.
1395 = 1 to 3 glow plugs open right side.
Check the VC connector.
475 Check connector for the EBPV at the turbo.
1000 = PITA to remove sometimes. (I/m ready code)
http://www.obdii.com/drivecycleford.html
Bill
Old Nov 28, 2007 | 11:47 PM
IDMooseMan's Avatar
IDMooseMan
The others sound correct.
P1000 = OBD 11 Monitor Checks Not Complete. More Driving Required.
P1395 = Glow Plug Monitor Fault Bank No. 1.
I'm adding P0475 to my list.
Old Nov 29, 2007 | 12:12 AM
kawa's Avatar
kawa
I didn't even connect the lead to the EBPV. Youse guys said it was OK to keep it disconnected. Right? Wrong?
Rog
Old Nov 29, 2007 | 05:42 AM
MADVAN's Avatar
MADVAN
Rog
YES.
It will store code disconnected.
Bill
