Sponsored by: Real Truck
No 4x4
Old Dec 13, 2017 | 07:27 PM
Will Reese's Avatar
Will Reese
No 4x4
I have a 2001 Ford f250 super duty 7.3 and I have no power going to my 4x4 switch. I have checked all the fuses and the relays and connections and I still have no power. Any help would be greatly appreciated!
Old Dec 13, 2017 | 08:10 PM
CousinCarl's Avatar
CousinCarl
Vacuum leak
Old Dec 13, 2017 | 10:05 PM
Lawnpro979's Avatar
Lawnpro979
I have had to swap the relays out with each other b4.
but I’m like the other reply, vacuum
Old Dec 14, 2017 | 01:09 AM
Mike189677's Avatar
Mike189677
How would a vacuum leak cause you to not have power at the 4x4 switch. The 4x4 switch is powered by electricity it doesn’t have any vacuum lines going to it, vacuum locks the auto hubs which don’t work due to vacuum leaks.
Old Dec 14, 2017 | 03:16 AM
seville009's Avatar
seville009
Here’s one of a bunch if threads on the switch power
https://www.ford-trucks.com/forums/1...-no-power.html
Old Dec 14, 2017 | 09:01 AM
StrangeBrew69's Avatar
StrangeBrew69
I had the same issue. Fighting with it for days. Turns out a connection in a wiring harness that I have unplugged to take the cab off had bent a pin over making no contact. Pulled the harness apart. Replaced the pin and reconnected the plug(more carefully this time) and 4x4 worked like it was new again.
Old Dec 14, 2017 | 10:09 AM
StrokinIT2001's Avatar
StrokinIT2001
Welcome to the club bubba.. I can share a trick with you if you can’t get it working... let me know.
Old Dec 14, 2017 | 10:10 AM
StrokinIT2001
where was was this pin (picture)? Do you know where all or most 4x4 connectors are?
Old Dec 14, 2017 | 12:00 PM
StrangeBrew69
My connector was located on the frame rail right in front of where the stock lift pump is located. I dont remember what pin number it was and dont have a pic at the moment. I can try and get you one later today or this coming weekend as the truck is now in storage for the winter.
Troy_455
Jul 13, 2015 08:37 AM
cornstar6207
Oct 19, 2013 10:15 AM
Crewcab Turbo
Jun 8, 2011 08:19 PM
rbrad6937
Feb 24, 2010 09:57 PM
Chris 97 F150
1997 - 2003 F150
Jan 15, 2007 12:29 AM
