Sponsored by: Real Truck
Help with this starter wire
Old Dec 13, 2017 | 02:45 AM
StrokinIT2001's Avatar
StrokinIT2001
And is there any way at all the starter can operate with it disconnected?
Old Dec 13, 2017 | 06:59 PM
jetjockey99's Avatar
jetjockey99
That wire is what actually activates the starter. I don't know how many amps it draws but it should be fairly low an no the starter will not work with it disconnected, as wired from OEM.
Old Dec 13, 2017 | 10:21 PM
StrokinIT2001
Would anything bad happen if I cut it and put a toggle switch into it?
Old Dec 14, 2017 | 10:48 AM
jetjockey99
If the switch is installed properly no, unless you forget to flip it back on.
Old Dec 14, 2017 | 10:56 AM
StrokinIT2001
how can it be improperly installed??
Old Dec 14, 2017 | 08:24 PM
jetjockey99
non insulated connections, connections too close to heat source melting, wrong type of wire as to temp and environmental considerations, etc.
Old Dec 14, 2017 | 09:09 PM
StrokinIT2001
I ran every bit of the the wires through some vacuum hose till it got to the cab. Used shrink wrap on the connections
bayslayer
Dec 5, 2011 04:26 PM
Critteracing
Oct 11, 2010 10:57 AM
fuzzy1626
Feb 15, 2010 02:41 PM
fkaster01
Apr 9, 2009 08:26 AM
