Need help shining 68 Grill
Dec 16, 2017 | 09:39 AM
Quote:
Originally Posted by
68FordTruck
I wonder if drop cloth plastic used for painting would work?
I’m not sure I would do that. You don’t want any holes look in the motar and stucco section. You should find some pretty thick poly.
Dec 16, 2017 | 11:14 AM
Do you remember how many gallons of water it held? I used an entire bottle of Crystal Drain on 5 gallons. that stuff ain't cheap.
Dec 17, 2017 | 09:13 AM
Measure your grill, length, width and height laying down flat and build accordingly.
The cost, time and labor involved is why I bought one from out Kingdom dentist. Time vs. money was the same.
Dec 17, 2017 | 05:14 PM
you could go to your local Tractor Supply store and get a galvinized horse trough .?
Dec 18, 2017 | 09:40 AM
spray on stuff doesn't require all this , just wet the ground below where you are working.
Easy cheesy.
Dec 18, 2017 | 09:53 AM
But, from what I have read, it sounds like the spray on does not get it off very good and you still have to do a lot of sanding.
Dec 18, 2017 | 10:08 AM
i did the spray , took off probably 95% . Multiple coats is the trick , keep it wet and foamy . I did mine in garage (shade) with fan next to grill (not blowing directly on it)
Dec 18, 2017 | 10:12 AM
Multiple coats , keep it wet and foamy , mine took off probably 95%
beats building a make shift bath tub IMHO .
Dec 18, 2017 | 10:13 AM
sorry fist post didn't appear till after i retyped second
Dec 18, 2017 | 01:04 PM
That sounds like the route to take. I'll probably give it a try in the next few days. Thanks for the info!
mattsf-100
Aug 13, 2007 12:12 PM
fordman102
May 9, 2007 05:09 PM
f-4x4
Mar 5, 2005 04:54 PM
txwing
Aug 5, 2004 11:58 PM
spider7613
May 10, 2004 09:26 AM
