1978 - 1996 Big Bronco
1985 Bronco Tachometer
Old Dec 11, 2017 | 08:31 PM
Locoforfomoco's Avatar
Locoforfomoco
Okay, I'm back with some more obscurities. What's it take to swap in the tach gauge set? I had someone say it was a direct plug-n-play, but I'm skeptical. One plug has more contacts than the other one and they're in different locations. Has anyone done this without butchery? Thanks again in advance
Old Dec 12, 2017 | 04:27 PM
AbandonedBronco's Avatar
AbandonedBronco
I put a stock tachometer into my '81 and my '84.
It is plug and play, but with a catch. When I did mine, I swapped in the entire gauge cluster since it also came with a tripometer, which I wanted.
Otherwise, you need the printed circuit board on the back of the cluster, which isn't easy to remove.
Which plug are you talking about? With mine, I unplugged the big plug out of the back of the non-tach cluster, and then plugged it into the new gauge cluster. Fired the engine up and the tach sprung right to life.
Old Dec 12, 2017 | 08:15 PM
McLeod's Avatar
McLeod
Here is a write up on the subject:
https://www.ford-trucks.com/forums/2...-f-series.html
f150v602
1997 - 2003 F150
19
Dec 7, 2017 10:08 AM
RadioControlGuy85
Aug 5, 2015 01:29 PM
matthew9283
1997 - 2003 F150
Oct 19, 2010 08:47 PM
Redneck1465
Mar 17, 2009 01:10 PM
DeGideo
Apr 21, 2002 04:41 PM
