instrument clusters
Old Aug 3, 2015 | 05:36 PM
RadioControlGuy85's Avatar
RadioControlGuy85
instrument clusters
got a 92 f150 5.0l auto.
were going to a junkyard in the next few days,im wondering if i can swap a cluster with a tach in?
iv read it can be done.but i one person saids it has to be a 94-95 or a 93-94.
can someone help me out?
Old Aug 3, 2015 | 10:50 PM
TexasGuy001's Avatar
TexasGuy001
You need a 92-93 cluster.
Old Aug 3, 2015 | 11:19 PM
Duvaren's Avatar
Duvaren
I believe the 92-97 tach is a snap in on the cluster.
Old Aug 4, 2015 | 07:33 AM
subford's Avatar
subford
The tachometer are the same for Gas clusters but there is no place to put a tachometer into a non-tachometer cluster.
Yes he needs a 1992-1993 cluster for plug and play.
Any other year will require wiring swaps from plug to plug.
Old Aug 4, 2015 | 07:42 AM
joegeds's Avatar
joegeds
As a testament to how easy this swap is, I was able to do it with no issues!! As Subford said, you need a 92-93 cluster that is not from a diesel. The only panel you will use from your current truck is the speedo/odometer panel. You will use the oil pressure/engine temp and the voltage/fuel gauge, as well as the tach from the donor vehicle.
Old Aug 4, 2015 | 02:50 PM
RadioControlGuy85
i seen on youtube that a guy swap a cluster out and just hooked it up and it work. can i do this if i get a 92-93 donor? or no?
Old Aug 4, 2015 | 04:21 PM
subford's Avatar
subford
Well yes but you will have the other trucks mileage on the odometer and wheel set up.
As stated above if swap your old center module (speedometer, PSOM & odometer) you will still have your trucks mileage and set up.
Old Aug 4, 2015 | 04:46 PM
RadioControlGuy85
i dont think it has the right mileage on it now. the od reads 88,889miles but if you look at the truck and under it. it doesnt look it.
ok so i need a 92-93 cluster.
thanks for the info.
Old Aug 5, 2015 | 01:29 PM
RadioControlGuy85
welp at pink n save we got the cluster bezel for 10 bucks no cracks or anything with the dual tank switch.thats a score. on ebay there wanting 100-200bucks.
the guy said they had complete truck,but they was on hold witch sucks.have to go back and check in a couple days or weeks for the other parts.
Holmesuser01
Jun 28, 2014 11:41 AM
Old93junk
1983 - 2012 Ranger & B-Series
Oct 20, 2013 08:33 PM
91 F-150 Farm Truck
Oct 25, 2007 12:36 AM
pikiluvi
Nov 23, 2003 06:30 PM
gimps
Bronco II
Oct 28, 2001 05:35 PM
